Engine swap experts needed!!
Old Sep 10, 2009 | 01:41 AM
GreyGT-C's Avatar
GreyGT-C
Default Engine swap experts needed!!
I'm at the point where i'm a few hours away from sticking the new engine in my vette and i just re-dropped the subframe....... and i found THIS lying on the front of it. Where does it go? I can't find anything that looks like it should be missing something that looks like it... This is where i found it... and of course, the piece in question.
Help?
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old Sep 10, 2009 | 06:38 AM
vsocks1's Avatar
vsocks1
Can't help with the part right now but I would suggest taking some time to cleanup some of the parts before I put it back together! Good luck with the install!
Old Sep 10, 2009 | 07:03 AM
AU N EGL's Avatar
AU N EGL
Looks like a bushing for end links on the sway bars
Old Sep 10, 2009 | 08:36 AM
knyght4's Avatar
knyght4
CANT... VIEW... PICS... FROM... WORK...
Old Sep 10, 2009 | 08:46 AM
lucky131969's Avatar
lucky131969
Help?
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
That bushing looks very clean...are you sure it's from this car?
Looks like a spacer for an idler pulley........
Old Sep 10, 2009 | 10:15 AM
DIXZ's Avatar
DIXZ
It looks like one of the alternator bracket bushings, but it is on the wrong side of the subframe.
Are there any bushings in the bracket for the A/C compressor?
Old Sep 10, 2009 | 10:42 AM
GreyGT-C's Avatar
GreyGT-C
yeah yeah.... it was being dropped back out so i could wheel it outside to the pressure washer..
def. not to the A/C...
I'll check the swaybar links shortly.
thanks... and keep the ideas coming.
Old Sep 10, 2009 | 01:02 PM
GreyGT-C's Avatar
GreyGT-C
too big to be swaybar end link bushing.....
Old Sep 10, 2009 | 05:18 PM
c5mtl's Avatar
c5mtl
when i do my engine swap im going to find all kind of lost nuts and bolts...i hope even some money....
To Engine swap experts needed!!
