Build Sheet
Old Sep 13, 2009 | 08:53 PM
korisu56's Avatar
korisu56
Default Build Sheet
Where do I find what engine, tranny, gear ratios, etc? I looked on the FAQ, but didn't see any links to where I can find it. Thanks.
Chris
Old Sep 13, 2009 | 09:23 PM
81c3's Avatar
81c3
Theres a sticker with all the RPO codes on it in your glove box.
Old Sep 13, 2009 | 09:24 PM
HowlinC5's Avatar
HowlinC5
Hate to tell you this but from what I found when I was inquiring about my C4 I had to order a build sheet from the corvette museum. I think it was $40.00 but they blow it up and it comes laminated. You can also get a replica window sticker from them. All they need is your vin#
Old Sep 13, 2009 | 09:31 PM
korisu56's Avatar
korisu56
Hate to tell me? That's awesome. hahah. I will definitely look into it. Thanks for both responses. Definitely different than any Jeep I've owned
Old Sep 13, 2009 | 09:45 PM
byronhunter's Avatar
byronhunter
According to the reading on this forum, there is a build sheet inside the front bumper. (metal Part) You would have to remove the front facia to get to it.
Old Sep 13, 2009 | 09:57 PM
djengr's Avatar
djengr
If you take your VIN# to a dealer they will typically be glad to run the Vehicle Information System (VIS) for you. It will give all the build option information on the vehicle, plus sometime they will print off vehicle maintenance (at least what is in their records). There are a few guys on the forum that will send you the VIS. (Spongevette did mine several years ago)
good luck
Old Sep 13, 2009 | 10:04 PM
korisu56's Avatar
korisu56
Thanks for the hookups guys.
Old Sep 13, 2009 | 10:19 PM
Its_Go_Time's Avatar
Its_Go_Time
That's where I found mine! Three years old and not very legible...but kinda neat too look at anyway.
Old Sep 13, 2009 | 10:25 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
Order the window sticker and build sheet from the NCM. It's worth it.
Old Sep 13, 2009 | 10:32 PM
korisu56's Avatar
korisu56
Yep, definitely doing THAT. Thanks for the hookup guys.
To Build Sheet
