Super Short Throw Shifter
Nope :nono:
Crappiest feeling shifter goes to..........Drum roll please.......
Porsche Boxster...Feels like a paint stick stuck in a gallon of latex wall trim.. :U
Maybe its time for a poll on the worst shifter! :lol: :lol: :lol: :cheers:
UR2SLW: I bought my spare shifter from the forum and it cost me $40.
Wow that is one short shifter. So to understand you correctly, you like the feel better than that of the Ripper. I still have my stocker laying around from my Ripper install. I may have to play around a little bit with it. How are the precision of the shifts compared to that of the Ripper.
Thanks for the input. :cheers:
I've got my stocker layin' in the garage.
Guess I've found a project for this weekend.
Might have to get this done this weekend and then try it out at the track next week.
Let me know if you have any questions. ;)
I have this really cool package shelf or divider in my car. I can put all kinds of stuff in it and they won't slide or roll away . It has 3 sections. I'd like to post a picture of it for you to see but I'm a computer idiot.
[Modified by Andy@AandACorvette, 4:25 PM 3/1/2002]
For what it is worth, I think the stock shifter could be shortened and modified in ways suggested here and be perfectly acceptable. Were I doing it again, I'd not fight the Ripper and probably just rebuild the stock shifter to suit me and, I suspect, be happier quicker.
All the best.
By the way, if you need dampening to control rattle or vibration, go to an electric motor shop and get shaft retaining sleeves in steel, held with a set screw. Install under the boot with lock tight. I used four on my modified Ripper, but useful on any shifter. Besides, the top one will hold the boot tight against the bottom of the ****--like a real car... :lol:
[Modified by Avanti, 10:11 PM 3/1/2002]
This was all geared to make your shifting easier.
http://www.breathlessperformance.com...ts/600-945.asp
Ernie
BreathlessPerformance.com
Anyway I started the modification and decided to take a slightly different approach. I figured there must be more shaft up inside that larger outer shaft. So I slit it with a dremel and found a complete shaft hiding inside. Also there is a cylinder filled with rubber which I think I'll try to keep. It will help dampen vibration also serve to keep the boot from sliding down. I think the shaft is already the perfect length (about 4") but It just needs to be threaded on the end. The an adapter is needed to mount the shift ****.
Do they make a male to female threaded adapter?
I kinda am looking for ideas here. What do you think? here are the pics...
[Modified by chuckster, 11:24 PM 3/2/2002]
[Modified by chuckster, 11:27 PM 3/2/2002]
[Modified by Andy@AandACorvette, 9:51 AM 3/3/2002]
I cut off my cylinder filled with rubber and there really is no vibration or noise to speak off. I kept the rubber boot to keep the dust out though.
Here are two images with the shifter in Neutral.
[Modified by benelliwang, 1:06 AM 3/3/2002]
I am still a little confused as to how you lowered the overall height of the shifter. Did you have to cut and then reweld under where the fluted part (top right in picture) was on the shifter? Just not sure what you had to weld back together (I think it is the stem on the left but I am unsure) but I was hoping that you could elaborate.
In other words, I am still trying to understand how you reused the stock stem in your modification.
Thanks. :cheers:
G Man,
Thanks. :cheers:
