Ring and Pinion Experts/Analyis
Old Oct 30, 2009 | 12:42 PM
  #41
CarBoy's Avatar
CarBoy
Originally Posted by 22655td
ROCKLAND STANDARD GEAR (George) in NewYork
WOW I would have never suspected that. This is the first time I've heard of an issue like this with them. I have a friend that does quite a bit of business with them, and they've always seemed to be pretty strait up, and know what they're talking about. This surprises me.
Thanks for updating us, and giving the heads up.
Old Oct 30, 2009 | 02:19 PM
  #42
22655td's Avatar
22655td
THE PINION IS THE KEY HERE THAT WEARS WHEN THEY IS TO MUCH LOAD
THE TIRES ARE AND MAY BE THE PROBLEM I HAVE TO SEE THE PINION FIRST
TOM
READY TO SHIP BACK
YOUR TOTAL IS 1655.00
TRANS U PAID FOR A RING KIT, 1/2 SYNCHRO AND GEAR
REAR U PAID FOR SUPER FINISH, KRYO AND BEARING KIT
IF U WANT TO PUT IT ON CC PLEASE CALL JENNY EXT 0 PLEASE GIVE HER THE CC INFO.
HAVE A GREAT WEEK END
GEORGE RSG
This is the only answer I got back when I ask why it wasnt warranty. Other than I am sorry you feel that way, when I told him I wasnt happy.
Old Nov 10, 2009 | 12:20 PM
  #43
milkman's Avatar
milkman
Tom, have you taken apart the rear they just send back to see what the pattern looked like??
Old Dec 14, 2009 | 07:20 PM
  #44
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
TOM
READY TO SHIP BACK
GEORGE RSG
this whole situation is pure BS..should be warrantied hands down..dispute the CC charge when you get it back
Old Dec 14, 2009 | 07:54 PM
  #45
SPS's Avatar
SPS
Probably both 22655td and Rockland know more about setting up gears than me, but what I do know is that gears are either set up perfect, or they are quickly trash.
Sounds like you found somebody who does mediocre work. That can be a tough business in the best of times when you only do mediocre work. You probably have already gotten as much out of them as they can afford to give you.
Steve
Old May 2, 2010 | 07:11 PM
  #46
The Highlander's Avatar
The Highlander
Sorry to drag this from the dead, but what happens when you do not have those A-B values?
Is there a Ring Pinion with a 3.90 that does have those values stated?
THe motive gears only has the A value, and I have been calculating the B value based on the difference from the whole case then dividing by 2.
I have built a couple but they still whine after 300-400 miles. Any thoughts?
