Shift Knob replacement
Old Sep 24, 2009 | 01:07 PM
ejoseph234's Avatar
ejoseph234
Default Shift **** replacement
My factory C5 shift **** has finally tore apart. I took off the top plastic piece with the shif pattern on it and now am stumped on how to take it apart and replace it. i have tried looking in past threads, but have found nothing helpful. Any help and sugestions on where to purches a aftermarket **** would be helpful.
Old Sep 24, 2009 | 01:34 PM
hotwheels57's Avatar
hotwheels57
Use search or search this forum in C5 Tech (in the red banner). Use keywords "removing demon key" and you'll find hundreds...maybe thousands ...of past threads.
This is the page you should come up with if you use those exact keywords in the manner I suggested...
http://forums.corvetteforum.com/sear...rchid=12590578
Here's just one thread...
http://forums.corvetteforum.com/c5-g...w-shifter.html
There are numerous manners to remove the "demon key" which secures the oem C5/Z06 **** to the oem shifter lever. After you remove the ****/demon key, you can decide on whatever **** fits your fancy. It needs to have 9/16-18" threads to fit the C5/Z06 shifter.
Any of the site supporting vendors should have a selection of *****. You can also find them in the classifieds. I use a HURST six speed **** on my car, which I bought from SUMMIT RACING.
Old Sep 24, 2009 | 02:23 PM
ejoseph234's Avatar
ejoseph234
Thanks for the help, figured it out now.
To Shift Knob replacement
