C5 Stock Resonators....(?)
Old Sep 24, 2009 | 11:45 PM
Luster's Avatar
Luster
Default C5 Stock Resonators....(?)
I've tried a search without much luck....
First, do C5's have resonators?
Second, will removing the resonators improve the exhaust sound without making the drone too loud?
My goal is to increase the sound level slightly, without spending a lot of cash on a cat-back system... I don't want it too loud. (I'm old and I'm cheap.)
Old Sep 25, 2009 | 12:05 AM
c5blkvetteguy's Avatar
c5blkvetteguy
I think you might be talking about the "pup cats" on the newer c5's.
Old Sep 25, 2009 | 12:16 PM
NassyVette's Avatar
NassyVette
There are no resonators per say. Rather than messing with emissions equipment which may not be legal depending on where you live, I would suggest looking for a used Z06 titanium exhaust in the for sale section. They can be had for a reasonable price, the look good, sound good (no drone, more throaty than stock), very light, and bolt in easily.
Old Sep 25, 2009 | 12:33 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
NO. There are NOT any resonators on any C5. The small cylinders just after the exhaust manifolds are pre or PUP CATS to help reduce cold start emissions. They are small and light off sooner than the down stream main CATS.
Removing or altering CATs will NOT improve your cars sound level. Adding Ti ZO6 CAT back mufflers will improve the sound of your car BUT,,,It will NOT ever make it sound like a true ZO6. The compression and CAM in a ZO6 is different than a base LS-1.
The ZO6 Ti mufflers will significantly improve the looks and remove 25 LBS of weight.
The only way that your going to improve the sound of your car is by adding an over the axel exhaust system. Find someone that has a system. Listen to it. If you like it COPY IT. Remember!! Engine mods can significantly effect the way an exhaust system sounds.
My Stainless Works complete LT Header system with a 3" mid pipe and over the axel muffler system sounded fairly tame at idle and part throttle. It was fairly loud at WOT! It had ZERO Drone. I added Heads. large cam and a FAST 90 & 90mm TB. Now the system is a beast!!!! I LOVE IT!
BC
To C5 Stock Resonators....(?)
