IAC COUNT (autotap) need help
Old Feb 22, 2002 | 02:30 AM
Tom Hall's Avatar
Tom Hall
Default IAC COUNT (autotap) need help
I'm trying to check the iac count, but can't seem to make it work. It stays on 160 no matter what size hole is in the TB Plate. I have the 2.05 version of autotap and the only thing I see for IAC is the IAC motor pinitle. I tried this on my other engine and couldn't make it work either. were I'm I going wrong? Thanks for any help.
Old Feb 22, 2002 | 10:45 AM
MelloYellow's Avatar
MelloYellow
Default Re: IAC COUNT (autotap) need help (Tom Hall)
Our TB setup is different than the F-Body.
I don't think you can rely on the IAC. Often it reads nothing. Sometimes you'll get a reading.
Our TB is electronically controlled or different somehow.
I don't recc drilling a C5 TB hole either.
Old Feb 22, 2002 | 11:00 AM
Tom Hall's Avatar
Tom Hall
Default Re: IAC COUNT (MelloYellow)
Yes, I know the TB is different, but was told by Wade at ARE that you could read the IAC count. ARE does drill the TB on their set ups. I have 2 holes :eek: I can't test drive my new Monster until I can get it to idle.
I do have Custom Programing and didn't think I would have that much trouble with the idle. Mail order Programing Sucks :smash:
Thanks for the response.
Tom
Old Feb 22, 2002 | 04:14 PM
MelloYellow
Default Re: IAC COUNT (Tom Hall)
Ya. I drilled my TB once. I wasn't happy with the result and replaced the TB blade with a new one. Doesn't seem to work as well on ours.
I've had very mixed results trying to read the IAC counter. Sometimes it will appear, but most often it reads out '0'. I'd post this at LS1Tech.com
Old Feb 22, 2002 | 04:26 PM
ToplessTexan's Avatar
ToplessTexan
Cruise-In II Veteran
And make clear you're talking about a Y-body not an F-body. :)
Old Feb 22, 2002 | 04:27 PM
Mike@NorrisMotorsports's Avatar
0Mike@NorrisMotorsports
Former Vendor
St. Jude Donor '11
Hey Tom,
I am not sure about Autotap as I use a Tech2. But the Vettes don't use IAC counts using the Tech2, only the F-Bodies do. The Vettes use throttle angle if it is possible to read that on Autotap, which is what I use with the Tech2. Call me if you need to.
Later,
Mike
To IAC COUNT (autotap) need help
