I suggest holding off on the trunnion upgrade. I installed it in my rockers on sunday and discovered that the rocker arms now will not rotate without a lever in the bolt hole to help apply force. Needless to say I chose not to install the rockers in my heads. I have a feeling the bearing races crushed too much and pinched the needles. Either my rockers have too small a trunnion hole or the bearings comp uses are a bit too large o.d. I sent them all off to comp and waiting for them to reply.
Now, even if the upgrade worked as implied I would probably not do it again. In order to do it correctly it takes quite a bit of time to install. I am very meticulous in my work and made sure everything was perfect which may have been why it took so long, but its the only way I do things. If you are paying someone to do it I'd say you are better off purchasing a new set of quality rocker arms. The main reason I chose the upgrade initially is because I personally like the design and construction of the factory rocker arms.
I hope comp will make good on this. I did call hinson, whom I bought the parts from, as well and the said they would help me out if comp doesn't. Just kinda sucks because I am now pushing my project further back by at least a week. I was hoping to start my car soon.
-V
Comp said they fixed my rockers and sent them out today. I asked if I did anything wrong and they said no. The problem was the bearings were pressed in slightly too far and the kept the trunnion from rotating freely. Comp said the solution is to install as I did and they smack the trunnion on a steel table, both side, to loosen everything up. I suggested they pack some directions in the box as I would have never known to do that. I'll see how they turned out as soon as I get them. I won't install them if they are not as free as the factory rockers. Hopefully they are as the stock rocker arms are very well done pieces.
Ive been running stock arms with a Comp cam over .600 lift at 7800 Rpms for over four years now and had zero troubles. I wont fix something that is not broken...
Recieved the rockers yesterday. They now are free to rotate so I will install them. The only thing I don't like is because of the snap ring design they can move side to side on the trunnion, but when installed that shouldn't be a problem.
Finally fired the motor last weekend and put about an hours worth of time on it. Everything works very well. I'll be on the track in the next couple weeks hopefully to see how my oil system upgrades work, but as far as the rocker upgrade I'd say thumbs up.
-V
Curiousity on my part, when you pressed them in was the outer race even with the rocker or are they recessed? I don't have the kit but am wondering how one might prevent repeating your hard learned lesson.
I don't remember, but when I talked to comp I installed everything properly. Basically press in all the way and after its all done smack each side of the trunnion ears on a hard metal surface. That frees them up just the right amount. I simply suggested they write up and include some directions. I rarely ever need directions, but that last step I didn't even consider.
