Column Lock issue's after 3rd recall modifications
I just purchased my 2004 Z06 about a month and half ago.
I just had the dealer do the 3rd and final recall on the steering column lock.
Afterwards I called the tech who completed it as the steering column would still lock (when you took the key out).
He mentioned that some of the recent jobs that he's done for the 3rd recall, the parts to remove the locking mechanism were not being shipped.
Also, since this 3rd recall was done, I am starting to get the "pull key, wait 10 seconds" message. I never had that before in the 4,000 miles I have put on the car.
So my question is:
I currently have been scheduled to go back in Oct 17th for them to remove the locking mechanism.
What is your opinion on this? Should I just tell him to go back to pre-3rd recall status (put the old harness in etc), and go aftermarket for the solution? My fear is: he'll remove the locking mechanism, but I'll be forever dealing with the "pull key, wait 10 seconds" message forever.
Sorry I am a newbie to the Vette thing, looking for some opinions with some good back ground and experience in this matter.
Thanks,
Andy
In this case however itis FREE being a recall.
For once I wanted to try it out.
Will the CLB fix work with the 3rd recall already completed? Or do I need to go back to original as delivered condition on the car?
Andy
Then, you can either stay with the GM relay harness, or go with an aftermarket CLB relay. Either one should work.
Also, once you remove the lockplate so that the column lock actuator pin cannot get in a bind, the actuator will likely last longer, and you might not even need the bypass.
I am thinking I will go with the CLB but remove the lockplate.
This sucks... I should have just ordered the CLB and been done with it. Oh well live and let learn. Thanks guys for the advice and your time.
Not sure when it was installed, it appears to be working just fine.
If it continues after the CLB install, I will probably change the battery out.
I checked the date of mfg of the battery (Aug 07). It is one of the premium Sears Platinum types. This is a very nice AGM battery.
However I don't know how the previous owner treated it.
I do think my battery volts is slightly low. I have been experimenting with how long I wait to turn the key on after the seat goes to the memory position, making sure the radar detector and cell phone charger are not turned on yet etc. I am also watching to see if I get the symptoms more as the outside temps drop.
All of the above leads me to believe that a replacement battery probably would help the situation, but if the CLB will rectify most of the symptoms, I may just hold on to the existing battery since it still starts the car like a champ. Why throw money out the window if not required.
Thanks so much for this information, this is exactly what I was wondering right now.
Actually I haven't been working with any voltages during my observations. More just experimenting with electrical loads before the key is turned to the on position and observing what are the results.
What I have been attempting to do, was try to give the battery a chance to recover slightly before turning the key to the on position. Batteries typically recover slightly after usage without a charge.
My theory on that is: I think it is do to a stratified voltage potential in the battery. A slight draw on the battery pulls power from the upper regions of the battery acid since this is the easiest path of least resistance. Once the draw is complete, I believe the acid is stratified then mixes to equalize (hence a recovery inside the battery). I could be wrong on this, but its my thought on the matter but I haven't researched this to see if my idea is correct or not.
I should also clarify to say that outside the battery, the voltage potential is a net sum of the conditions inside the battery since the unequal potentials have a common connection (the battery posts). I don't know if I worded this very well, but I tried. Again I could be wrong, but I am just exploring the idea with you.
Thanks, in advance, for your valued assistance.
Les
I took your advice and read David Gourno's post on how to unlock the column. It worked great, first time. Thank both you and David very much. Just another of many examples how forum members take care of each other.
Thanks again
Les
http://forums.corvetteforum.com/show...ghlight=unlock
Some patience and persistence with it should get it unlocked. Once you do install the CLB immediately!!!
I have seen a writeup on how to remove the lock plate but you have to replace it with a special version (has no holes for the lock pin) since the plate itself serves several purposes. It contains the horn ring contacts, causes the turn signals to cancel and physically provides the spacing between components that are stacked ontop of one another on the column. I know that a few have used a Dremel or small die grinder to cut the lock pin off so that it could no longer lock.
I'll look for the plate removal thread and post it here if I can find it again.
Worked like a champ.
Now, I am thinking of removing the K harness.
Is there any good threads with pics of how to do this?
http://forums.corvetteforum.com/show...ight=k+harness
it was installed between the actuator and the connector that goes to the BCM. A correctly installed CLB disconnected the male connector of the K Harness from the female connector that is attached to the bottom of the dash behind the drivers side knee bolster. If you connected the CLB to the female connector of the K Harness you have NOT installed it correctly. The female connector of the K harness is easily recognizeable since it has only two wire connected to it, a white wire and a purple wire and it is NOT attached to the bottom of the dash. If you plugged the CLB into that female connector the CLB is doing nothing but going along for the ride. The K Harness is still responding to the BCM lock and unlock signals.
If your car did NOT have a K Harness installed then the only male connector of the correct size and shape would have been from the actuator. When you disconnected it from the female connector attached to the bottom of the dash and plugged the CLB into that female connector you correctly installed the CLB.
While its been a couple hours and a couple beers since I did it...
If KNOW I found the 4 wires (green, black, orange, etc), broke the connection and plugged it in.
Before I installed the CLB, the actuator worked and locked the steering wheel.
Now that I am done, the actuator does not work.
I wonder if they even installed the k harness like they said they did. I don't remember seeing any other goodies up there.
That being said, you have me paranoid, even though all works, I am going to open it up in the morning and confirm.
Thanks for your time.
Andy
Sure enough, the K harness was indeed installed, and I did indeed connect up to the female side of the K harness. I wasn't paying enough attention to what I was doing.
That being said, I just removed the K harness and attached the CLB to the BCM side where it should have been all of the time.
You just kept me out of trouble.
Thanks for taking a few minutes of your busy day to help a fellow Vette owner.
Andy
