Running on Empty
Old Oct 5, 2009 | 10:35 AM
HDRyder's Avatar
HDRyder
Default Running on Empty
I have been having the fuel gauge problem for several years and I am constantly adding Techron & always using premium brand gas with Techron in the gas.
That has not solved the problem. Yesterday on a trip back from Dallas to Lou, KY in 10 hours of rain the needle went to empty and then it stopped runninng at 330 miles along side the interstate.
After AAA got there and I refuel, it only took 12 gals, 8 gallons remaining yet it acted as if it was empty.
Any ideas on the problem before it goes to the shop. As it is, can't trust what it will do in the future.
Old Oct 5, 2009 | 11:01 AM
TurboBerserker's Avatar
TurboBerserker
It sounds like you might not be getting all the fuel out of the RHS tank. Maybe the siphon pump is partially plugged or otherwise malfunctioning.
BTW, my fuel gauge is also a strange one. I've run a bunch of seafoam through it, but any time I completely fill the tank the guage goes nuts until it's under 3/4 and still showed 1/8 tank last week when it ran out of fuel...
Here's a thread which might be helpful:
http://forums.corvetteforum.com/c5-t...post1571514483
I became aware of that thread from Bill Curlee's post:List of c5 repair post that everyone should have!
Old Oct 5, 2009 | 05:21 PM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
You may have a kink in the fuel line that passes between the two tanks. I had this happen on my C6. Make sure whomever you bring it to knows what they are doing. Good luck.
Old Oct 6, 2009 | 09:24 PM
HDRyder's Avatar
HDRyder
Thanks for the replys. I guess it will be going in the shop and will be at their mercy. I will have them look for a kink in the line.
Old Oct 7, 2009 | 10:15 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
He's referring to the "crossover tube" which connects the fuel supply from the filler neck to both tanks.
To Running on Empty
