Cooling system flush question?
Old Oct 6, 2009 | 12:37 PM
B-STOCK's Avatar
B-STOCK
St. Jude Donor '14-'15, '17, '19
Default Cooling system flush question?
I have been having the dealer power flush the cooling system and change the coolant on my 2000 Vette. The last time I had it done was 12/06 with 19K on the car. I now have 24k on the car and am wondering if I should have it done again before I put the car away for the winter.
Also, any tips on changing it myself. I have a four post lift so access should not be a problem.
I have a 2005 LS2 GTO that has to be done also. Any difference in draining the coolant or system on the LS2?
BTW, the last time I did this kind of work was in the 70s so I really don't know where to start.
Thanks,
Mike
Old Oct 6, 2009 | 12:48 PM
Black04Z06's Avatar
Black04Z06
Thanks,
Mike
I followed this procedure. My fluid was still clear from the factory on my 2004.
http://www.iammoon.com/c5tech/coolant_drain.htm
If there is a better one then we need post it up
