Power windows and keyless entry not functioning
Old Oct 8, 2009 | 01:57 AM
VetteND's Avatar
VetteND
Default Power windows and keyless entry not functioning
I have a 99 HT that has started acting up. First the keyless entry quit working and then the passenger window stopped functioning fallowed by the driver’s window. I can hear the relays when the window switches are pressed. I have tried manipulating the wiring between the door and body with no luck. Could this be a ground issue or maybe a BCM connection? Any help would be appreciated.
