Needed spec sheet for 224/228 cam
Oct 13, 2009 | 12:38 AM
I bought this cam 224/228 LSA 114 a while back and don't have the spec sheet and want to install it this weekend. Anyone have a spec sheet for it
Model No 54-000-11
Grind number 3722R / 3724R HR114+
Cam Spec INT EXH
ADV DUR 273 277
DUR@ .050 224 228 LOBE SEP: 114.0
Valve lift .581 .588
Also known as a 6016 on AFR site.
I have done a check on comp cams website and nothing comes up.
Thanks.
Oct 13, 2009 | 07:26 AM
Oct 13, 2009 | 09:02 AM
Call comp. With the model or grind number(forgette what one they need) they can pull the spec card and give you everything you need to know.
Oct 13, 2009 | 10:54 AM
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
I have the same cam! pair it up with some nice heads and it makes awesome power!
Oct 13, 2009 | 12:47 PM
I have the cam card at home for my AFR 6016 cam. If you still need it let me know and I can scan it in as long as it is OK with AFR if I post it.
Oct 13, 2009 | 06:07 PM
OK, that was stupid
I got home and went to get my installation book with the cam card and realized it is at work, where I posted the above. I will get it tomorrow.
Oct 13, 2009 | 08:37 PM
Oct 13, 2009 | 09:22 PM
Same cam here with +4* advance, works great! Vengeance Racing might be able to tell you also, its a VRX2. I would try comp first though.
Oct 14, 2009 | 09:51 PM
Just sent via e-mail. Let me know if its OK
Oct 15, 2009 | 06:06 AM
2002 ,
224 ,
224228 ,
228 ,
581 ,
588 ,
6016 ,
afr ,
c5 ,
cam ,
camshaft ,
card ,
comp ,
corvette ,
sheet ,
spec ,
specs ,
ve
