Reverse Lockout No Longer Works! Ideas?
Old Oct 13, 2009 | 10:44 AM
1slowFRC's Avatar
1slowFRC
Default Reverse Lockout No Longer Works! Ideas?
Just like the title says...reverse lockout doesn't work anymore and won't stop me from shifting into reverse while driving (easy to do when shifting from 4-5). I was hoping someone could point me in the direction of a possible fix?
Old Oct 13, 2009 | 11:11 AM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
Has there been any recent work done on the car? The plug for the solenoid may not have been pushed on far enough to engage the lock tab. The solenoid might be bad as well.
Old Oct 13, 2009 | 11:22 AM
1slowFRC's Avatar
1slowFRC
No recent work has been done, but where would I look to check the plug for the solenoid or possibly change out the solenoid?
Old Oct 13, 2009 | 01:24 PM
stngh8r's Avatar
stngh8r
You may be able to "push through it", but I don't recommend it. I am in the process of reinstalling a trans right now and one of the biggest issues was the reverse.
What started out as likely just the solenoid, ended up in no reverse at all and a marred up shifter.
Good luck
Old Oct 13, 2009 | 01:40 PM
1slowFRC's Avatar
1slowFRC
Good luck
If you mean by "push through it" to push it into reverse, I can do that just fine. The car goes into reverse at a stop like normal, but when I am driving the transmission is not supposed to allow you go into reverse and it does and now I am nervous shifting from 4-5 and no way am i going from 3-5...
From the looks of it this isn't going to be an easy fix
Old Oct 13, 2009 | 02:30 PM
BigJimZ16's Avatar
BigJimZ16
I had the exact same issue on my Z06 CE. Gets very nerve wracking to drive doesn't it!! The fix is to change the solenoid that is located on top of the transmission. The part list price is $166.00, I ended up giving $106.00 for it at the local Chebby Dealer. The FSM calls for the rear section to be dropped a few inches to gain access. I was able to change the solenoid in about 10 minutes on my lift. I'm tall with long arms which helped. You won't get it reaching up from a laying position on jack stands!! Good luck... and happy shifting
Also, the lockout will set a code in the DIC but won't generate a CEL. An open or shorted coil should both generate the code. Mine did NOT set a code. Obviously there was some mechanical reason in the assembly for the problem. Some day with more time I'll take it apart...
Old Oct 13, 2009 | 02:54 PM
1slowFRC's Avatar
1slowFRC
Thanks for the response...So, basically I need to put her up on a lift and it shouldn't be too difficult? Do I still need to lower the tranny on the lift?? or can i just reach up there?
Old Oct 13, 2009 | 03:34 PM
BigJimZ16's Avatar
BigJimZ16
I used a 1/4" drive ratchet, 13mm socket (I think); I put my right cheek right up against the bottom of the diff. facing forward, I was able to feel the plug and the single blot that attachs the lockout assy. If you have Popeye arms you're screwed... I din't have to lower the rear section at all. By the way, if you have the FSM, it only deals with the electrical part of the lockout assembly. That requires alot more room. Take my advice and change the whole assembly. That's the way GM sell it anyway. My guess is that your failure is the same as mine and it's in the assembly where the solenoid action moves through a right angle. Take your time and keep the new assembly clean. Make sure the o-ring is lubed with a drop of oil.
Old Oct 13, 2009 | 05:04 PM
byronhunter's Avatar
byronhunter
You're getting some good info here, but it wouldn't hurt to do a little troubleshooting first. What would you say if you changed it, and later found it was just a fuse?
Old Oct 14, 2009 | 02:45 AM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
In my case I over looked the wiring for that connector when I did the clutch. Pulled both wires out of the connector. I was able to get under the car on stands and bear hug the tranny. I found the problem and I took the pins out of the connector and soldered the wires back and put it all back together. Works fine. Had a code, hard to shift into reverse, would go into reverse while hunting 5th, but no message or cel. In any event do a little investigating before swapping parts.
Old Oct 14, 2009 | 10:58 PM
Bill Dearborn's Avatar
Bill Dearborn
All the lockout does is place a spring loaded mechanism in place so it is hard to shift into reverse. The mechanism is designed to be overridden in case of a failure that leaves the lockout in place when the car is stopped. That way the car can be moved if required. Anybody can override their lockout if they use enough force to push past the spring.
Bill
Old Oct 15, 2009 | 09:35 AM
1slowFRC's Avatar
1slowFRC
Thanks for the info guys...I will check the fuse first and then if that's not it I will check that solenoid when I can get up to my garage in Tulsa (currently at OU).
I am hoping it's just a fuse, but honestly I doubt it...Just curious, but if I somehow pushed past that spring am I screwed?
Old Oct 15, 2009 | 07:06 PM
BigJimZ16's Avatar
BigJimZ16
Buy the part, change the part! A quick look at the schematic should tell even the most casual observer that it feeds other circuits... Duh, how many other problems are you having??
The GM part # you want is 19133262.
Old Oct 15, 2009 | 07:22 PM
1slowFRC's Avatar
1slowFRC
This is the only problem I am having. It's not as easy as just buying the part and changing it...I need to have tools and being in college away from my house makes things I little more difficult
I appreciate the part number and hopefully this will fix the problem.
Old Oct 15, 2009 | 07:33 PM
clemsondave's Avatar
clemsondave
Here's a diagram:
Old Feb 7, 2010 | 12:05 PM
jrC599's Avatar
jrC599
I think I just had this problem last night but didn't catch it in time. I am at a loss now, cause I don't know if it means I need a whole new trans or if they can fix mine. I must of pushed through and grinded it while trying to shift into 5th. I don't have a reverse now. back up lights come on but the car doesn't move but just grinds
Old Feb 7, 2010 | 12:32 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
I did this too lol
Old Feb 7, 2010 | 12:56 PM
ragtopws6's Avatar
ragtopws6
Originally Posted by clemsondave
Here's a diagram:
Hey Dave, that diagram is incorrect! The reverse lock out is on top passenger side of the trans. #1 and #2 is mixed up. To the OP, here is what you should be looking for. It's the one just above the vent tube.
To Reverse Lockout No Longer Works! Ideas?
