Help shifter problems!!!
Old Oct 13, 2009 | 10:27 PM
kdeal's Avatar
kdeal
St. Jude Donor '09
Default Help shifter problems!!!
Guys here's the deal.
My C5 has just broke the 100k miles mark. All of a sudden the other day my regularly sloppy shifter became completely loose, to the point where I have to make 2 tries at finding the outside gears. Has anyone had this problem or know how to fix this? I assume it wouldnt be as easy as installing a new shifter..... Its weird, I put the shifter in a gear and the whole shifter will move to the right or left several inches while in gear. Any suggestions or am I looking at a multi-thousand dollar investment here? Luckily Winter is coming..
Old Oct 13, 2009 | 10:29 PM
bumble-z's Avatar
bumble-z
Sounds as though your shifter base is loose. Pull the console and your shifter/base is right there. Good luck.
Old Oct 13, 2009 | 10:56 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
Start there.
Old Oct 13, 2009 | 11:31 PM
c5blkvetteguy's Avatar
c5blkvetteguy
And do an alignment on it.
Old Oct 14, 2009 | 12:14 PM
dbstephens's Avatar
dbstephens
I had the same problem on my 04 Z06, when I removed the stock shifter and replaced it with a C6 shifter. The two hold down bolts backed out after time and the entire unit became sloppy; even jumping out of first at random, own its own.
I removed the console, as mentioned above; placed the shifter in neutral and reinserted its aligning pin (at the front of the shifter), to hold the unit in position, then retorqued the mouning bolts with red Loctite applied. Problem solved with crisp responsive shifts once again.
Old Oct 14, 2009 | 12:49 PM
hotwheels57's Avatar
hotwheels57
Red LOCTITE is unnecessary on a 1/4-20" fastener, especially on the thin cast "box" beneath the shifter mechanism. That's for larger fasteners under lots of stress. It'll require heat to remove...
http://www.loctiteproducts.com/produ...id=48&plid=154
Blue LOCTITE and correct spec torque will work just fine and will be easier to remove in the future...
http://www.loctiteproducts.com/produ...id=48&plid=153
Old Oct 15, 2009 | 12:17 AM
kdeal's Avatar
kdeal
St. Jude Donor '09
I took the day off work on Friday, I will post as I go. I appreciate the quick response on this. DB, it is constantly popping out of 1st!. Wish me luck guys.
To Help shifter problems!!!
