BCm code B2723 pass key detection circuit?
Old Oct 17, 2009 | 05:15 AM
memphis_vette's Avatar
memphis_vette
Default BCm code B2723 pass key detection circuit?
what does this code mean? i broke my key last week got a new one. both old key and new key make me have to wiggle the ignition to start the car. am in need of cleaning the ignition pins for the resistor or do i need a CLB?
thank you
cody
Old Oct 17, 2009 | 11:57 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
First, did you insure the pellet in the key you bought is the correct one? If you aren't sure, use a DVM and measure the resistance of both. They should be within a couple of ohms of each other. If they are the same, then the contacts at the edge of the ignition switch are done and need to be replaced. I think its available seperately from the ignition but don't hold me to that.
Old Oct 17, 2009 | 12:16 PM
Bill Dearborn's Avatar
Bill Dearborn
The code just says there is an open or short in the PassKey theft deterrent circuit. How did you break the key? Was it in the lock cylinder when it was broken off? You don't need a CLB as that will not solve this issue. Since you can get the car to start by jiggling either key you have the correct pellet on the new key. Your problem is in the cylinder or the cylinder wiring harness connector. Either the contacts are dirty or worn. If the key was in the cylinder when it was broken maybe something happened to the contacts at the same time. You can get some contact cleaner that is safe for use on plastic parts and use it to clean the key and then squirt it into the cylinder and move the key in and out to help clean the contacts. Also pull the wiring harness off the lock cylinder and check for any loose connections or corrosion in the contacts. If that doesn't solve the problem you are probably looking at a new cylinder.
Bill
Old Oct 17, 2009 | 05:05 PM
memphis_vette
thank you guys ill give that a try
To BCm code B2723 pass key detection circuit?
