Need help
Old Oct 23, 2009 | 02:39 PM
freakshow346's Avatar
freakshow346
Default Need help
I PUT 20s ON MY CAR AND THE CAR HAS BEEN RUNNING LIKE ITS BEING HELD BACK AND THE CHECK HANDLING SYSTEM CAME ON THE MESSAGE BOARD FEEL FREE TO CALL 201 390 7343 THANKS
Old Oct 23, 2009 | 03:51 PM
zeevette's Avatar
zeevette
What are your tire's overall diameters, front and rear? The rears need to be at least 1/2" taller than the fronts, or you activate the limp-home mode. Hard to drive it that way. EIther that, or you bought 80lb wheels, and it just feels that way.
Old Oct 23, 2009 | 06:53 PM
freakshow346
Default now what
the fronts r 1 inch taller never thought ov this what is the answer
Old Oct 23, 2009 | 07:42 PM
byronhunter's Avatar
byronhunter
Originally Posted by freakshow346
what is the answer
Read post #2.
Old Oct 23, 2009 | 07:57 PM
03WhiteConv's Avatar
03WhiteConv
Since you have 20s all around, I am assuming that you have the same tires on all 4?
Maybe you could swap out the rear rubber for something taller? I wonder if you went slightly taller in the rear and lowered the front end a bit if it would do the trick. Not sure if that would look funky or not. Anyone know?
I thought I read somewhere that the sensors for the body control were under the pass seat.
Just a thought. More of a question for the group than advice.
You could also buy a set of 19s for the front and try to sell the 20s as rears, but I bet you'd lose big on the deal with only 2...
Old Oct 23, 2009 | 08:19 PM
Indy's Avatar
Indy
I don't understand what you're saying??!!! Why would the fronts be taller?
TC can't handle same size front and rear. Compensate with right tires...
Old Oct 24, 2009 | 10:44 AM
freakshow346
i dont underestand myself i have to get a taller tire or drive with the traction control always off
Old Oct 24, 2009 | 11:12 AM
dougbfresh's Avatar
dougbfresh
Put the stock wheels back on, CAN YOU UNDERSTAND THAT? Then try to READ POST #2 AGAIN it's not rocket science dude. Driving w/ TC off is STUPID.
Old Oct 24, 2009 | 12:14 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The OVERALL HEIGHT of the REAR tires M U S T be 1/2" taller than the OVERALL HEIGHT of the FRONT tires.
If the FRONT and REAR tires are the same height,,, the wheel speed sensor data from the rear tires will make the Electronis Brake Traction Control Module (EBTCM) think that the rear wheels are loosing traction and it will apply the brakes to correct the problem.
Put shorter height tires on the fronts OR taller tires on the rears.
Old Oct 24, 2009 | 12:28 PM
freakshow346
u should b easy with your answers ! IF SOMEBODY SPOKE THAT WAY IN PERSON THE RESULTS WOULD NOT FAVOR U DOUG B NOT SO FRESH
Old Oct 24, 2009 | 12:32 PM
freakshow346
Thanks bill ! The place that i got the rims and tires from r correcting the prob taller in back :d
Old Oct 24, 2009 | 02:43 PM
Jnape's Avatar
Jnape
While we are on this subject, will a LARGER difference cause a problem. I am putting on C6Z wheels and tires on my '02Z. The difference is 1.1" taller in the rear. '02Z stock has a .7" taller rear. Any thoughts?
Thanks,
John
To Need help
