Checking Auto/trans fluid
Old Oct 27, 2009 | 06:13 PM
shaggyvette's Avatar
shaggyvette
St. Jude Donor '10-'11-'12, '19, '21
Default Checking Auto/trans fluid
Ok I give up. I've searched and searched and I can't find anything on how to check the auto/trans on my 01. Cant find the dipstick. Help
Dave
Old Oct 27, 2009 | 07:20 PM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
There is no transmission dipstick on C5's Dave. The level is checked by removing the transmission fill plug,which is located on the left side of the transmission pan.
The engine must be running, car level, and the transmission fluid temperature between 86-122 degrees, before you remove the plug. The fluid level should be at the bottom of the fill plug threads.
Old Oct 27, 2009 | 07:38 PM
old stingray's Avatar
old stingray
Old Oct 27, 2009 | 08:08 PM
shaggyvette
Thanks guys, you are the best.
Dave
Old Oct 27, 2009 | 08:24 PM
Quicksilver Vert 01
Dave
Dave, PM me if you need any more info. about it.
Old Oct 25, 2012 | 08:01 PM
RedC5's Avatar
RedC5
Anyone check and find a low tranny fluid level? How many miles if you did find low?
Old Oct 25, 2012 | 08:15 PM
lucky131969's Avatar
lucky131969
The fluid cannot evaporate. If you don't have a leak, it could remain at the full level indefinitely. Do you have a leak?
Old Oct 26, 2012 | 04:33 PM
Bluefire's Avatar
Bluefire
FWIW, you can only check the fluid level when the fluid temp is between 85F - 122F.
You're welcome.
Old Oct 26, 2012 | 06:25 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
UNLESS,,, a previous owner or service center checked it wrong and never refilled it. Seen that one a few times.
If you don't follow the EXACT procedure,, when you remove the fill plug, you will wear a whole lot of fluid!!!!
Bill
Old Oct 26, 2012 | 07:08 PM
RonSSNova's Avatar
RonSSNova
It is a complete stupid pain in the *** to fill or check.
Old Oct 26, 2012 | 07:10 PM
RedC5's Avatar
RedC5
I bought my C5 new in '98 and with 55K, been way to lazy to check it...no runs, drips, or errors. I hope Bowling Green filled 'er up
Old Nov 21, 2012 | 08:58 AM
Quicksilver Vert 01
Your taking a big risk by completely ignoring it!
For the sake of transmission longevity, it would be wise to change your fluid and filter very soon.
To Checking Auto/trans fluid
