98 Headlight Problem??
Old Oct 29, 2009 | 03:25 PM
Corvette ED's Avatar
Corvette ED
From: Pottsville, PA. USA Home Of America's Oldest Brewery Yuengling
Default 98 Headlight Problem??
98 Convertible the left headlamp works fine comes up and goes down. The right side will not come up. The motor does nothing. I checked the fuses and they are ok. Could the problem be in the module?
Old Oct 29, 2009 | 03:53 PM
Oldvetter's Avatar
Oldvetter
Try turning the manual over-ride a few turns and then try. If it comes up, your gear is stripped. If not, it could be module or motor or wiring. Make sure all connections are tight and not corroded first. Use a volt ohmeter to see where power is (or is not).
Old Oct 29, 2009 | 07:26 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
If the fuses are good, there are only a couple of components in the system The headlamp controller (mounted on the right forward frame rail behind the right headlamp) and the headlamp/multifunction switch on the column. The usual failure is the headlamp switch but first you'll need to know if the motor is getting any power at all. Also, the ground for it (I think its the one) is on top of right frame rail adjacent to the hood riser.
Old Oct 29, 2009 | 07:53 PM
byronhunter's Avatar
byronhunter
dgrant3830, he says the Left works perfect, in that case, it would not be the Headlamp Switch.
Old Oct 30, 2009 | 01:25 AM
dgrant3830's Avatar
dgrant3830
Yeah, that's possible unless the headlamp switch has a set of contacts for each lamp. I really didn't and don't know therefore I added it in there just in case. We've seen more headlamp switches lately too. In the OP's case, its probably as stated, the gear itself. The tale might be told if he's able to manually crank it up or not as the gear would have to work for that to be able to happen. Also, once its up, when the headlamps are switched off, does it close itself?
Old Nov 15, 2009 | 11:20 AM
Corvette ED
I tried the manual override and the light comes up but will not go down with the switch. My guess is that either a bad ground or the module is the problem.
Old Nov 16, 2009 | 06:32 PM
Corvette ED
I found the problem was the module. Switched it with another car and it solved the problem.
To 98 Headlight Problem??
