c6 z06 output shafts
Old Nov 3, 2009 | 07:28 PM
winters97gt's Avatar
winters97gt
Default c6 z06 output shafts
I am going to buy a complete rear end from DTE or RPM. It looks like I broke one of the shafts last weekend, and I would rather just buy a complete built rear end with a new gear.
I have noticed that both the DTE and RPM stage 2 kits come with the c6z06 output shafts. Are these strong enough to handle launches with drag radials with 425rwhp? How much stronger are they over the c5 z06 shafts?
Old Nov 3, 2009 | 07:31 PM
lucky131969's Avatar
lucky131969
Great question for DTE or RPM.....no?
Old Nov 4, 2009 | 10:03 AM
chevylad's Avatar
chevylad
You're on your own with wheel hop, but there's an article in one of my magazines with a 10 sec C5 with only 4.10's and a C6 output shaft (I forget which side, it's the long side)
Old Nov 4, 2009 | 10:45 AM
smoothblue's Avatar
smoothblue
St. Jude Donor '12
Should be the drivers side..
Old Nov 4, 2009 | 10:49 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Old Nov 4, 2009 | 10:55 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
If you're going buy a built differential, look into installing a tranny brace.
I got a much better differential for sale that'll cost you the same as the ones you're looking at.
This way if you make more power etc... you ain't going to have to buy another one or spend big bucks doing it over.
Old Nov 4, 2009 | 11:18 AM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Hi Mark,
It just so happens that we are running some diff specials this month, bring your car on back.
Jason
Old Nov 4, 2009 | 11:20 AM
LoneStarFRC's Avatar
LoneStarFRC
Old Nov 4, 2009 | 11:35 AM
corvettebob1's Avatar
corvettebob1
No hardened output shaft or C6Z06 output shaft will handle wheel hop.
At your power level the stock ones should hold fine W/O wheel hop.
If per chance you get your axle shafts to hold the next thing that will break may very well your trans output shaft.
Old Nov 4, 2009 | 11:53 AM
ragtopws6's Avatar
ragtopws6
Here is the difference between the 2 shafts. GM part # 89060119 and lists for $69 compared to $300 plus for 300M hardened output shafts.
Old Nov 4, 2009 | 12:53 PM
winters97gt
Originally Posted by Cajundude@EnglandGreen
Hi Mark,
Jason
done Thanks for the taking care of me. See you guys when the rear end comes in. Thanks!
Thanks for the replies guys. I don't think wheel hop broke my car, if you have seen the video. The initial hit from my spec 3 clutch did the job, as far as I can tell.
http://www.youtube.com/watch?v=ElYUTdQswqA
Old Nov 5, 2009 | 10:31 AM
corvettebob1
Yeah, it looks like it broke on the first bounce.........
To c6 z06 output shafts
