passenger vanity mirror
Old Nov 5, 2009 | 05:03 PM
john V. zemba's Avatar
john V. zemba
Default passenger vanity mirror
It has been a while since I have been on ,used the forum alot when I restorded my 78 but now I have an 02 , Just purchased it and need info on vanity mirror it is falling off the visor was there any clips that hold it in place or drawings that show me exactly how it should be if clips where can I get them ,
Old Nov 5, 2009 | 05:30 PM
jimmymc's Avatar
jimmymc
check this link,http://forums.corvetteforum.com/c5-t...with-pics.html
Old Nov 6, 2009 | 09:23 AM
john V. zemba
thanks it worked great
Old Nov 10, 2009 | 10:27 AM
jimmymc's Avatar
jimmymc
your welcome
Old Nov 10, 2009 | 05:15 PM
DeeGee's Avatar
DeeGee
This is my solution to the problem
Sun Visor Fix
I also had a problem with this and I tried a couple of things before I got one that worked. I also used zip ties:
Pull the mirror away from the housing gently. Stick a piece of 3M double sided tape along the inside edge of the top of the mirror between the two holes in the visor.
Thread a small zip tie through each hole from the back and outside of the hole, with the “head” of the tie located in the large rectangular recess. Pull the tail of the zip tie towards you and thread from inside to out through the hole in the locating pin. Push the tail through the head loosely at first.
Use needle nosed pliers (holding the tail) and a precision screwdriver (pushed against the head) to tighten the zip ties. Be very careful when pulling the ties tight not to pinch the lighting wires which run through the same hole. Once tight, snip the spare tail of the tie but carefully so as not to snip the electrical wires.
Push the mirror back into its housing and press firmly against the double sided tape.
Should be good as new.
To passenger vanity mirror
