Service Active Handling
Old Nov 6, 2009 | 01:38 PM
SearayC5's Avatar
SearayC5
Default Service Active Handling
So just recently my car started to flash "service active handling"/"service vehicle soon". While driving with the cruise control on it will deactivate it at random. Also the car will trigger the active handling for a split second while braking lightly sometimes. Any thoughts?
Old Nov 6, 2009 | 03:26 PM
trussme's Avatar
trussme
Default What Codes R U getting?
post your codes...you can get them this way:
with the key in the on position, but the engine not running
push and release the reset button until all messages cleared
next push and HOLD button #4
next push and release button #1 four times while holding button #4
When first engaged the on-board diagnostics go into an "automatic" mode which shows all parameters: PCM-TCS-RTD-BCM-IPC-radio-HVAC-LDCM-RDCM-SCM-RFA. If there are no problems, you will see "no more codes" on the ICP display. The computer will show two kinds of codes, "current" and "history," designated "C" or "H". A current code indicates a malfunction is present in the system whose module is displaying data. A history code indicates a past problem. When the screen displays "manual diagnostics," select the desired module by pressing the "options" button to go forward or the "trip" button to go back. Press "gages" to go forward or "fuel" to go back. To exit the diagnostic mode at any time, press "E/M".
If you want to erase or "clear" codes, press .""reset
