tires
Old Nov 8, 2009 | 10:54 AM
cobra3's Avatar
cobra3
Default tires
About due for some new tires and thinking about changing and getting away from the run flats. My question is how wide of a tire can I put on the stock rear wheel on a 02 coupe , what brand does every like the best. Thanks for the info
Old Nov 8, 2009 | 11:01 AM
lumpdady's Avatar
lumpdady
I went with KUHMO and I love them but I didn't widen I stayed with factory specs. One thing you will realize that once you leave run crapps you will enjoy the ride oh so much
Old Nov 8, 2009 | 05:42 PM
Dave68's Avatar
Dave68
With stock wheels, I personally wouldn't go larger than 285/35s, but you can definitely go wider with Z06 wheels. I am a huge Goodyear GSD3 fan - amazing tires, dry and wet.
Old Nov 8, 2009 | 06:20 PM
Boulty1961's Avatar
Boulty1961
I am happy with Kuhmos. Factory tire size on mine.
If you are not going to have runflats any longer then may I suggest one of these kits or one like it.
http://www.slime.com/product/281/Pow...%2370004).html
Old Nov 8, 2009 | 06:23 PM
Jnape's Avatar
Jnape
Goodyear GSD3. Tirerack or any Goodyear dealer has GREAT deals on this very good tire.
Old Nov 8, 2009 | 07:04 PM
guido7834's Avatar
guido7834
If you are not going to have runflats any longer then may I suggest on of these kits or one like it.
On both counts
Old Nov 8, 2009 | 07:48 PM
0331MARINE's Avatar
0331MARINE
From: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
I have Toyo T1R's on my 01 I went up a size in the rear to a 285 and left the fronts stock size.
Old Nov 8, 2009 | 09:39 PM
2Phast4U's Avatar
2Phast4U
From: anywhere you go, there you are Bentonville, Arkansas
I am also in need of tires for my '04 and have been wondering if I go run flat do I stick with factory or look at getting away from run flat. I will be watching the comments on your post to see what the opinions are.
Old Nov 8, 2009 | 09:42 PM
0331MARINE's Avatar
0331MARINE
GET RID OF THE RUN-FLATS. Your Corvette will love you for it. The ride is 100% better. I dont regret it one bit.
Old Nov 8, 2009 | 10:55 PM
padojada's Avatar
padojada
Kumhos spt's are real good tires minimal road noise and grat grip. check out tire rack they should be on sale.
Thanks,
Paul
Old Nov 8, 2009 | 11:02 PM
c5blkvetteguy's Avatar
c5blkvetteguy
Old Nov 8, 2009 | 11:06 PM
pcbunn's Avatar
pcbunn
Lots of good tires out there to choose from but for my '01Z I went with Michelin ps2's. They are consistantly rated the best performance tire.
Old Nov 9, 2009 | 10:35 AM
wcsinx's Avatar
wcsinx
Because I'm a cheapskate, I went with Sumitomo HTRZ IIs. They're $80 front and $110 rear at TireRack. I have been very pleased with these tires. They were a little noisy at first, but after about 300 miles that went away. Grip is excellent ... no tread squirm at all even right after I put them on. The front's treadwear rating is stupid low though at 220, but hey at $80 a pop I can wear out 2 or 3 of these for the price of an F1.
Old Nov 9, 2009 | 10:40 AM
03WhiteConv's Avatar
03WhiteConv
So when you loose the runflats, do you keep the TPM sensors and just balance or are they replaced with standard valve stems?
Old Nov 9, 2009 | 11:00 AM
cobra3's Avatar
cobra3
thanks for all of the reply's and I do have a small air pump for the car I just need to get some plugs or some sort of flat repair to put in the vech along with the pump.
Old Nov 9, 2009 | 06:24 PM
Cybermind's Avatar
Cybermind
I have been asking myself the same question. Also, if TPM sensors are removed, is there a way to permanently turn off the DIC error message?
Old Nov 9, 2009 | 06:38 PM
racebum's Avatar
racebum
understand the logic BUT the kumho spt is a FAR superior tire for just a little more money.
to the OP, you need a goal before any real advice can be made. do you need
1. max dry traction?
2. all season?
3. 3 season?
4. what can you spend?
To tires
Old Nov 9, 2009 | 11:46 PM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
You can keep the TPS system. The non flat tires are just like run flats. Except for the built up part in the center.
I went cheap with Falken 452's on the back. I just checked this weekend and it's been a year since I put them on and they are wearing extremely well. The tread wear rating was good as well except I can't recall the number. I will be replacing the Kumhoes on the front with the 452's shortly.
Old Nov 10, 2009 | 12:24 AM
91Vette's Avatar
91Vette
I ditched my runflats and went with General Exclaim UHP. Compared to the runflats, these tires are awesome
Old Nov 10, 2009 | 10:04 PM
supersupereight's Avatar
supersupereight
Goodyear GSD3s on mine..
I heard they are being discontinued from some other Cf members 2 weeks ago.
Tirerack had limited amounts left and were pricing them to move.
Better hurry if its the tire you want!
