Valve train
Old Nov 14, 2009 | 01:43 PM
LVZO6's Avatar
LVZO6
Default Valve train
What are you running with success?
GEN III Block
What roller lifters?
Spring seat # open/closed?
Max Lift?
Rocker ratio?
Max RPM?
Noisy?
Need some input to make a decision.
Old Nov 14, 2009 | 03:31 PM
vettenuts's Avatar
vettenuts
Not sure what you are asking, do you need stock information?
Old Nov 14, 2009 | 03:46 PM
LVZO6's Avatar
LVZO6
I knew I would forget something. I updated the thread. Is that clear enough?
Old Nov 14, 2009 | 04:48 PM
vettenuts's Avatar
vettenuts
Here's my setup.
GEN III Block
What roller lifters? Morel
Spring seat # open/closed? 155 lb/407 lb
Max Lift? .581/.588 (lift being run)
Rocker ratio? 1.7
Max RPM? 6,600 (intentional fuel cutoff), combination has been run higher
Noisy? Not bad, FAST intake made it worse
Old Nov 14, 2009 | 06:08 PM
LVZO6's Avatar
LVZO6
Default Yep
Here's my setup.
This is what I'm looking for.
To Valve train
