Tail-light wiring harness
Old Nov 15, 2009 | 04:17 PM
Jason's Avatar
Jason
CI 4-5-6-7 Veteran
Default Tail-light wiring harness
The weather pack on the passenger side has gotten into my muffler and partially melted. There are 7 wires coming in, and 6 wires coming out. As best I can tell, the red wire 'H' on the inboard side does not have a corresponding wire on the outboard side. Is this correct? Everything else i can just splice straight together?
Old Nov 15, 2009 | 05:36 PM
byronhunter's Avatar
byronhunter
You need to explain better. The Passenger side rear lamps should not have a red wire. (I don't think!!)
Old Nov 15, 2009 | 05:46 PM
byronhunter
By any chance is it a Eroupean Export model. it has a red wire for the rear Fog Lamps!
Old Nov 16, 2009 | 10:17 AM
Jason's Avatar
Jason
CI 4-5-6-7 Veteran
No, not an export model. This is the wire harness in the passenger rear wheel well. Comes from transmission and ABS sensor into a plug, then plug runs to tail-lights. There is one more wire coming "IN" than going "OUT". This wire is red and in the "H" slot of the connector.
Old Nov 16, 2009 | 11:13 AM
byronhunter
Looking at this Schematic, I'd forget the red wire??????
Connector Part Information
15326842
10-Way F Metri-Pack 150 GT Series (BLK)
15326847
10-Way M Metri-Pack 150 GT Series (BLK)
Pin
Wire Color
Circuit No.
Function
Pin
Wire Color
Circuit No.
Function
A
BRN
9
Park Lamp Feed
A
BRN
9
Park Lamp Feed
B
LT GRN
24
Backup Lamp Feed
B
LT GRN
24
Backup Lamp Feed
C
GRY
120
Fuel Pump Motor Feed
C
GRY
120
D
BRN
641
Ignition Positive Voltage
D
BRN
641
E
PNK
339
E
PNK
339
F
LT BLU
20
Center High Mount Stop Lamp Feed
F
YEL
820
G
GRY
1524
Backup Lamp Input
G
GRY
1524
Backup Lamp Input
H
RED
122
Rear Fog Lamp Feed (Europe)
H
RED
122
Rear Fog Lamp Feed
J
ORN
1040
RTD Relay Solenoid Supply
J
ORN
1040
K
DK BLU
1944
RTD Relay Control
K
DK BLU
1944
RTD Relay Control
To Tail-light wiring harness
