Engine Shutdown at Track?!
Old Nov 16, 2009 | 12:58 PM
Lunchbox_Killa's Avatar
Lunchbox_Killa
Default Engine Shutdown at Track?!
I drive a 2002 C5, effectively stock. My last two races at California Speedway, my car has shut down during high speed turns. In the middle of the turn, I will all of a sudden lose everything.... all gauges going to 0 and the engine shutting off having to coast off the track.
Once I pull off, the car starts up fine and I can drive it off and even home. In fact, it does not do it at any other track. I think the high speeds at California Speedway have something to do with it. The car is not overheating, this will happen in the morning after only two laps.
Prior to it happening the first time I had a pretty bad power steering leak. I somehow associated it with that and replaced both the pump and rack. I will be going out again this weekend for retest.
However, before I waste the track fees, I was hoping for any input or experience from anybody else who might have had with this problem.
Thanks guys!
Old Nov 16, 2009 | 02:18 PM
FourG63 97GST's Avatar
FourG63 97GST
this is rather interesting.
I'll start off in the fuel department, maybe the pumps overheat? but it is cool enough by time you're done coasting, so restarts fine. I'll get a gauge on there an log fuel pressure if possible. next step i'll check would be in the tune, do you datalog?
Old Nov 16, 2009 | 02:41 PM
Millenium Z06's Avatar
Millenium Z06
Moderator
Check your oil level, you are probably pulling the oil away from the pickup during the high speed turn and the sensor sees no oil and shuts the engine off.
Old Nov 16, 2009 | 03:04 PM
AU N EGL's Avatar
AU N EGL
How much banking ( clock wise or counter Clock wise )and how little fuel did you have?
Low few, bank tracked, pulls fuel away from the pick up, car shuts down.
also bank tracks and oil pick up( or lack there of) are almost a disaster waiting to happen. Make sure you run at least 1 quart over. Which will still not prevent oil starvation and a dropped valve.
Old Nov 16, 2009 | 03:16 PM
Lunchbox_Killa
I agree with all of you. Unfortunately, the actual turn it shuts down in is flat. I will look into adding the extra oil and monitoring my fuel pressure. I appreciate all the interests and concern. I will let you know what happens at the track this weekend.
Old Nov 16, 2009 | 06:53 PM
mathia's Avatar
mathia
The engine shuts off, but the there's still power to everything, right?
I've had issues on track with low fuel causing me to loose power in the turns, but the engine didn't completely die. This was at Spring Mountain raceway in my mostly stock '01 coupe on street tires with about an 1/8 of a tank.
Maybe if you're pulling more G's, the engine would completely shutdown, but I'd think you'd also see it loosing power on other turns with less G's. Do you remember how much fuel you had when this was happening?
Old Nov 20, 2009 | 08:12 PM
Vince99FRC's Avatar
Vince99FRC
Funny you mention your car shutting off. Whenever I go WOT w/out the datalogger mine shuts off, but cranks right back up when I turn the key on and off. When I roll into it the car is fine. I never get a code. I am very curious to whats causing this myself.
To Engine Shutdown at Track?!
