18 all around
Old Nov 21, 2009 | 10:01 AM
3whit's Avatar
3whit
Default 18 all around
Anybody running 18 in all around on their C5, I think I would like to try it because of tire size availability etc. Thinking 18X9.5 front , and 18X11 rear if possible.Let me know what you have done ,tire sizes ,offsets , ,Prefer not to tub ,Thanks for any help ..
Old Nov 21, 2009 | 10:19 AM
YeloFevr's Avatar
YeloFevr
Many people have done it. Just make sure the rear tire is slightly taller than the front.
Old Nov 21, 2009 | 11:14 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If you dont run taller tires in the rear, the EBTCM will have serious issues!
Old Nov 21, 2009 | 11:56 AM
Slow Z06's Avatar
Slow Z06
Got 18x10.5 on all corners.
285.35.18 front and 305.35.18 rear
No problems
Old Nov 21, 2009 | 12:08 PM
mojo1's Avatar
mojo1
St. Jude Donor '06 thru '15, '19
My fronts are a tad bigger so I have to turn the TC off all the time, sure makes the backs wear out a lot faster....
Old Nov 21, 2009 | 12:22 PM
3whit's Avatar
3whit
Thanks TXZ0603 that is the kind of info I am looking for ,I am running C6 wheels now 18/19 ,Have to get rid of the run flats so thought I would really make a change, Any pics of yours ,3whit@comcast.net ,Thanks for your help...
Old Nov 21, 2009 | 12:28 PM
Slow Z06's Avatar
Slow Z06
Old Nov 21, 2009 | 02:21 PM
3whit's Avatar
3whit
Very Nice ,That what I am wanting to achieve .Thanks for your efforts .
Old Nov 21, 2009 | 04:15 PM
69dodgecharger's Avatar
69dodgecharger
No problems
Same exact set up I use, tire sizes and all. Works great!
Old Nov 21, 2009 | 04:16 PM
99 vett babycar's Avatar
99 vett babycar
275/35/18 ; 295/35/18
Old Nov 21, 2009 | 04:27 PM
AU N EGL's Avatar
AU N EGL
18s here too.
Lots of guys run 18s all around with no problems.
the 17-18 of the C5 and the 18-19 of the C6 are for cosmetics only.
Old Nov 21, 2009 | 07:55 PM
westez's Avatar
westez
Running 18's all around. 265x35x18 on 18x9.5; and 295x35x18 on 18x11's......
Old Nov 21, 2009 | 09:01 PM
CTD's Avatar
CTD
No problems
Brutal !!
I've been struggling a bit with my traction problems.....you have nailed it.
Photo's
Tx's
Old Nov 21, 2009 | 10:25 PM
flycastinguy's Avatar
flycastinguy
295/35/18's on 18x10.5's on all 4 corners with no AH/TC issues.
Old Nov 22, 2009 | 07:42 AM
AU N EGL's Avatar
AU N EGL
I think Bill is correct, unless you have a 98 or 99 and or you just dont go hard enough through corners. J/K
Personally I think our cars are much more neutral handling with identical tires on all four corners,
When I used GY G19s at 18x11.5x25.5 my car cornered far better then ever. But since those tires were about a 45 compound, they only lasted a few weekends.
Yes I had to turn AH/TC off to do high speed corners.
Now I run 18x305/30 and 18x335/30
Old Nov 22, 2009 | 08:45 AM
3whit's Avatar
3whit
That must look just Nasty .What a stance !!!!!
Old Nov 22, 2009 | 10:40 AM
CTD's Avatar
CTD
I've thought about running 295 on the front, by chance would you have photo looking down from top of the fender at the tire?
My CCW's are 10 wide in the front, Toyo offers a 295 size for my 19" rims. That would save me from replacing my current rims.
To 18 all around
Old Nov 22, 2009 | 11:54 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If you have Active Handling, thats when the problem can crop up. The active handling system is more sensitive to tire sizes than the non AH system.
BC
Old Nov 23, 2009 | 02:31 AM
striper's Avatar
striper
I have CCW Classics 18x10 front and 18x11 rear. I run 265/35-18 and 295/35-18 tires. The 265's are the same diameter as the stock 17" fronts and the 295's are the stock rear size on my Z. Everything fits perfectly and looks good, too. After many thousands of miles I've had absolutely no issues at all. The tires sit right at the edge of the wheel wells and give a very tough look the way they fit even with my car being lowered.
Old Nov 23, 2009 | 08:13 AM
WKMCD's Avatar
WKMCD
I run CCW Big Street Classics 10.5x18 front and 11.5x18 rear with 275x35 and 315x30 PS2's with no tubbing and they are flush to the rear quarter panel.
