LS3 427 Shortblocks - $4995!!
Old Jan 18, 2010 | 09:48 AM
HinsonSuperCars's Avatar
0HinsonSuperCars
Former Vendor
From: Birmingham, AL www.hinsonsupercars.com 205-909-9402
Thanks for your orders!
Old Jan 18, 2010 | 11:14 PM
Mike94ZLT1's Avatar
Mike94ZLT1
Doesn't a crank with a throw that long pull the piston skirt out of the bore? I know on LS1 and LS6 blocks a 4" crank is cutting it extremely close...
(from the guy running a 382 )
Old Jan 19, 2010 | 01:28 PM
zeevette's Avatar
zeevette
I think the LS3 block has longer skirts.
Old Jan 26, 2010 | 12:33 PM
0HinsonSuperCars
Former Vendor
The piston is shorter for this combination. For this NA application, it works great to achieve big cubes.
Seth
Old Jan 26, 2010 | 11:27 PM
CorvetteDave01's Avatar
CorvetteDave01
What kind of rpm can these motors handle?
Old Jan 29, 2010 | 10:10 AM
0HinsonSuperCars
Former Vendor
That will all depend on the top half of the motor.
Seth
Old Jan 29, 2010 | 10:40 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
Seth, is there another option to keep the LB option around 7k?
ie: L92 heads?
Old Jan 29, 2010 | 11:44 AM
GFCmgb71's Avatar
GFCmgb71
oh my god i want one of these so bad it hurts
Old Jan 29, 2010 | 06:11 PM
0HinsonSuperCars
Former Vendor
ie: L92 heads?
With WCCH L92 Heads, GM LS3 Rocker Arms (Intake), and GM LS3 Rocker Stands, you'll save $963.50.
Seth
Old Jan 30, 2010 | 12:06 AM
67Ranger's Avatar
67Ranger
Just for some info on K1, they are the Chinese brand of carillo (one of the nicest racing rods out there). Much like compstar is the Chinese brand of Callies. The parts I have seen from them are very nice, and much better than eagle/scat, at least as far as machine work and consistency goes.
Old Feb 13, 2010 | 08:28 PM
C6R557's Avatar
C6R557
do a ported ls2 heads work on the ls3 427ci shortblock
Old Feb 13, 2010 | 08:57 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
Seth
The heads will be very good, but is there a down side to the GM LS3 Rocker Arms (Intake), and GM LS3 Rocker Stands on your build
Old Feb 13, 2010 | 09:28 PM
  #33
C6R557's Avatar
C6R557
no ls3 rocker arms or ls3 rocker stands
Old Feb 13, 2010 | 10:12 PM
  #34
C6R557's Avatar
C6R557
does the ls2 crank work with this engine specification
Old Feb 14, 2010 | 11:33 AM
  #35
LoneStarFRC's Avatar
LoneStarFRC
......like that other brand.........Compstar??? owned by Callies
Yup Compstar = Offshore
Dragonslayer = U.S.
Magnum = U.S.
That's why I chose their Dragonslayer crank, but that's just me.
Old Feb 19, 2010 | 06:01 PM
  #36
0HinsonSuperCars
Former Vendor
They will work, but not make as much power.
The upgrade would be to switch to Yella Terra Roller Rocker Arms for reduced friction and wear.
It will work, you'll just have a much smaller displacement.
Dragonslayer = U.S.
Magnum = U.S.
All of the Callies components are available through us as well.
Seth
Old Feb 19, 2010 | 06:49 PM
  #37
Leukic's Avatar
Leukic
This so makes me just want to buy this and slap it in the C5 instead of a FI cause the price is right. Nice pics
To LS3 427 Shortblocks - $4995!!
Old Feb 23, 2010 | 06:56 PM
  #38
0HinsonSuperCars
Former Vendor
Old Feb 25, 2010 | 03:45 PM
  #39
kh400's Avatar
kh400
How many teeth on the crank reluctor on this engine? Just wondering about installing one of these in my '03 base C-5? Thank you.
Old Feb 25, 2010 | 03:53 PM
  #40
kh400's Avatar
kh400
Eagle and Scat are also made off shore. The dirty little secret in the industry is that all cranks and rods in this price range are made off shore. Some of the manufacturers finish the product in the states and some do not. A true made in America solution is available, but those pieces carry a premium of 2 or 3 times higher cost. Those are also available through us, and we prefer that our customers buy American when possible.
LS3 Block vs. LS7 Block
The LS3 Block is $1,142 cheaper than the LS7 Block.
LS3 427 Shortblock vs. Stock LS7 Shortblock
The LS3 Block is $1,142 cheaper than the LS7 Block. The longer stroke makes more torque. The forged internals will handle a higher power capacity.
Seth
So the pistons are forged?
