LS3 427 Shortblocks - $4995!!
Old Feb 25, 2010 | 07:36 PM
  #41
ajg1915's Avatar
ajg1915
St. Jude Donor '08
What kind of pricing on a forged LS3 with stock cubes and WCCH L92 head option ?
Old Mar 5, 2010 | 12:27 PM
  #42
HinsonSuperCars's Avatar
0HinsonSuperCars
Former Vendor
From: Birmingham, AL www.hinsonsupercars.com 205-909-9402
Originally Posted by kh400
How many teeth on the crank reluctor on this engine? Just wondering about installing one of these in my '03 base C-5? Thank you.
We'll use 24x for your C5. They're available with both 24x and 58x.
So the pistons are forged?
Yes.
You'll save $164.04 with the stock stroke and you'll save $963.50 with the WCCH L92 setup.
Seth
Old May 7, 2010 | 09:50 AM
  #43
C6R557's Avatar
C6R557
how much would it cost for the ls3 427ci without the crank and rods .
Old May 7, 2010 | 12:16 PM
  #44
AU N EGL's Avatar
AU N EGL
Engine **** Pictures. ahhhh
made my day. TYVM
Question:
the LS3 427 with the 4.25" stroke vs the LS7 427 with the 4.00 stroke, what would be the rpm difference, and which would provide more torque in the 2,000 to 3,500 rpm range?
ie out of corners and UP to speed. Yes I do know that each engine is specific for the intended build purpose.
TIA
tom
Old May 7, 2010 | 09:42 PM
  #45
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
i want one. has the turn ket price dropped since the dow went down 1000 points
Old May 8, 2010 | 07:35 AM
  #46
AU N EGL's Avatar
AU N EGL
Yup the floor or oil pan was dropped out.
Old May 8, 2010 | 07:48 AM
  #47
phils C5 vette
Old May 10, 2010 | 03:59 PM
  #48
FL1BY's Avatar
FL1BY
Cruise-In IV Veteran
Yes.
Seth
Seth,
Thank for answering alot of questions WITH pricing information. It is appreciated, and as soon as I get back from Kuwait I will be in touch. Thanks
Old May 19, 2010 | 05:28 PM
  #49
0HinsonSuperCars
Former Vendor
$1549 - GM LS3 Block
Piston prices are available here http://forums.corvetteforum.com/c5-t...1-diamond.html
made my day. TYVM
Question:
TIA
tom
Were using a 4.125" stroke. The larger stroke will make more torque. We recommend using the 4.000" stroke in road racing applications because it allows you to use a better piston design that's going to be beneficial in extended high rpm. The biggest difference in power curves and rpm levels is going to be in the top end of the motor, since the LS7 block will accept LS7 heads and the LS3 block will accept LS1 or LS3 heads. The LS7 parts typically make more power in the 6500-7000 range and the LS1/Cathedral parts typically make more torque.
Originally Posted by FL1BY
Seth,
Sounds great
Seth
Old Aug 10, 2010 | 10:07 AM
  #50
0HinsonSuperCars
Former Vendor
Thanks for your orders!
Old Apr 24, 2011 | 11:52 AM
  #51
Jack Daniels's Avatar
Jack Daniels
So it sounds like all the interals on this one are forged, but it is probably not best for boosted applications because skirts too short/piston might pull out of cylinder?
If so, what would be a proper stroke that would not compromise boost capability, and what would the cubic inches come out to on that one?
Old Apr 27, 2011 | 04:57 PM
  #52
0HinsonSuperCars
Former Vendor
Yes, everything is forged. The piston is shorter for this combination, so it's not recommended with forced induction. For a forced induction application, we recommend using a 4.000" stroke, which would make it 415 cubic inches.
Seth
