unknown cam question
Old Nov 27, 2009 | 07:53 PM
hatewhatownsyou's Avatar
hatewhatownsyou
im trying to measure the lift, but how the f do you turn the motor over? the rack is in the way to get a socket on the crank and i dont have that size wrench, i tried the alternator but its just spinning on the belt.
i was hoping MTI could give me some info but im not gettin any response
Old Nov 27, 2009 | 08:13 PM
c5vetteski's Avatar
c5vetteski
Default cam reply
i have a 99c5 with a mild cam i changed my springs to patriot gold springs and i hear ticking all the time. i dont think you have any thing to worry about
Old Nov 27, 2009 | 08:48 PM
Its_Go_Time's Avatar
Its_Go_Time
If you pull the plugs out, she'll turn over a lot easer. The only problem is the lifters will have bled down some, reducing the amount of lift you'll see at the valve. This will be especially true if the valve you try to measure was sitting open for a while. A better way would be to remove the rocker arm, and set up the indicator directly against the end of the pushrod. The light spring inside the indicator wont be able to move the piston inside the lifter. If you're careful, you can get a very accurate measurement like this. Just make sure the indicator is in line with the pushrod.
Old Nov 27, 2009 | 08:51 PM
hatewhatownsyou
do you think its worth the time or am i just runnin in circles?
Old Nov 27, 2009 | 09:27 PM
Slow Z06's Avatar
Slow Z06
MTI Houston does not exist any more as a performance shop. They started selling cars and dont do any type of auto related work.
Old Nov 27, 2009 | 10:14 PM
Its_Go_Time
If it were my car, I'd sure like to know what cam it had in it. Before beginning though, I'd find a listing of mti cams with intake/exhaust lifts that I could compare my measurements to.
Old Nov 28, 2009 | 01:02 AM
tail_lights's Avatar
tail_lights
Depends. Do you really want to know the specs? Then no. Are you just a bit worried about the springs? Then yes, get some duals and call it a day
Old Nov 28, 2009 | 05:57 PM
hatewhatownsyou
alright, i pulled 2 of the rockers off, int& exh im gettin about .350 at the push rod. so that comes out to be .595 lift at the valve. which is ALOT for stock springs correct?
the car has MTI racing stageII heads, and their stage 2 cams have .581 lift. those are the closet # i can find. i checked the R1, X1, stage 1,2 & 3.
i was spinning the motor backwards, it wouldnt spin clockwise, the belt was just slipping.
somone had rockers in it i believe, they removed the baffles in the covers.
also, what would make a spark plug gap close? detonation?
all the plgus have some oil on the threads, my guess would be because it never had the recall done on the oil rings.
Old Nov 28, 2009 | 08:14 PM
hatewhatownsyou
also, what are the chances these are pac springs? lookin on their web site they are the same color, or does the orange paint indicate for sure they are stock?
Old Nov 28, 2009 | 08:15 PM
Its_Go_Time
.595 is quite a bit of lift for a stock spring! those beehive springs you have could very well be stock, but of course you can't really be sure just by looking at them. Quite a few aftermarket companies make this style of spring. The next step would be to measure the stiffness of a couple of the springs and compare that to the stock specs. Though, at this point, I would just consider changing them for new ones. You need good set of springs for that cam...you've established that.
Old Nov 28, 2009 | 08:19 PM
hatewhatownsyou
im going to go with the PP dual extreme spring kit, nice kit for a nice price.
you have any idea about that spark plug?
Old Nov 28, 2009 | 08:28 PM
Its_Go_Time
No...it looks really white though. *Just talking outa my ****, but maybe its running to hot/lean? I believe a white color can indicate that. I wonder what's been going on in the tuning department...
Old Nov 28, 2009 | 09:41 PM
  #33
hatewhatownsyou
the guy i just bought it from had it dynoed/tuned at carslile this year,
Old Nov 29, 2009 | 05:51 AM
  #34
mojo1's Avatar
mojo1
St. Jude Donor '06 thru '15, '19
not sure where the op is located, but I think there is another MTI up north.
