Those with two piece timing covers..
Old Nov 29, 2009 | 06:19 PM
73 LS-4's Avatar
73 LS-4
Default Those with two piece timing covers..
Just kinda an FYI. If you have the edelbrock two piece timing cover, and have to change your water pump you may have to grind the bolts down on the back of the impeller housing. I found this out the hard way when I couldn't get my water pump to sit flush and seal correctly. Just trying to save someone else from doing this twice as I did myself
Pat Kunz
Old Nov 29, 2009 | 08:06 PM
TheGovernorZ06's Avatar
TheGovernorZ06
i had no issue w/ the QTP one... edelbrock was not out at the time...
