Quick Lowering Question
Old Feb 28, 2002 | 09:14 PM
OliverM5's Avatar
OliverM5
Active Streak: 90 Days
Default Quick Lowering Question
Can I (How do I) get to the front end lowering bolts(while the car is sitting on the ground) to adjust the height a little bit? What kind of tool do I use? Also, is adjusting the rear as simple as turning the nut? Thanks in advance.......
Old Feb 28, 2002 | 09:21 PM
Andy@A&ACorvette's Avatar
Andy@A&ACorvette
Platinum Supporting Vendor
Default Re: Quick Lowering Question (OliverM5)
Can't do it on the ground. There is too much pressure/ friction on the end of the adjuster. It's pretty hard to turn it with the weight off it. I usually support the car by the frame and then jack the spring up a little to take the pressure off. Even then it's hard untill you get it loosened up a bit. It takes a 10 mm wrench or socket. It's easier with the wheel off but can be done with it on also. You can adjust the rear the same way. Just loosen the nut on the big bolt. Again it's easier with the pressure off but not nearly as critical as the front. ANDY
