ABS problems.
Old Dec 1, 2009 | 07:01 PM
fwarren's Avatar
fwarren
Default ABS problems.
I have a 1998 ABS Module that has a problem. When I install the engine the ABS system has never worked right. Example when I slap the brakes on, the ABS is not kicking in and then when the car comes to a stops the DIC say the ABS has activated. Now I looked for codes and I have none. So I sent the head of the unit to ABSFIXERS and they say this one they can not be fixed. I would assume that if the module or a wheel sensor is bad it would set off a code . I have not Ideas? Need help!!!
Old Dec 2, 2009 | 06:22 PM
sjbrothers's Avatar
sjbrothers
Default ABS Active is a good response
I also have a 98 abs system and just came in form the rain where I exercised my ABS several times. When you apply brakes hard enough to activate the ABS then the DIC displays ABS Active . No error is posted as it si working as designed.
Old Dec 2, 2009 | 08:21 PM
trackboss's Avatar
trackboss
I had to replace the unit in my '99. ABS fixers could not repair it, but tried at no charge. Great company. Its a horror story that I went through with another repair place that you can search on here and find. It was a couple years ago. I simply ended up purchasing a new one and it still works well. No one to this day has been able to answer why the older units cannot be repaired. At least not by a reputable place like absfixer.
To ABS problems.
