I have a 2004 CE Z06 I purchased in Sept of 2008 with 5500 miles on the clock. This past Nov. when fueling it up, gas started running out from under the car on the driver's side (10,000 miles). Thankfully this was at a Shell gas station that had a car wash with an underbody flush.
Quote:
Nathan Ong
Defects Assessment Division
Office of Defects Investigation
NHTSA
I just finished e-mailing Nathan, and will register my complaint with NHTSA also.
My car was modded in Sept with an A&A kit and upgraded in-tank fuel pump as well. Car has been fine until recently. Will this "Void" any claims I might have?
I also will be contacting the dealership to see what they have to say about it.
The "squeaky wheel" gets the oil....so lets start squeaking out there
everyone that has fuel leak problem, fuel vapor smell, leaks on the fuel system dealing with the crossover or tanks, or anyone that has had this already fixed, please send a complaint to (NHTSA.gov).
I didnt know about this until yesterday, and filled out the complaint. You will need your vin number.
This is a faulty system designed by GM and they should be held accountable for it.
I just spent 2350.00 on a tank replacement. I will file tonight. Thanks.
My late 2004 Z started leaking fuel while refueling after it was about 4 months old and they replaced the tank (well that's what the repair order said).
LVZ06,would you please report this to the NHTSA even though you have had the tank replaced.Every report of the problem will help to get GM to do the right thing.
I have my 03 in the shop now with a gas leak.. Having to drop the bottom out, just to get to the gas tanks. Unbelievable---also big repair bill.
