Instrument panel backlight problem - Please help!
Old Dec 6, 2009 | 04:49 PM
canadian_Vette_guy's Avatar
canadian_Vette_guy
2nd Gear
Default Instrument panel backlight problem - Please help!
While on vacation in Florida I just purchased my first Corvette. I bought a 2002 Convertible and once returning home to Canada I noticed that the speedo/tach back lights are only working intermittently. All the other gauges aside from the speed and tach are working fine (radio, HUD buttons, heater and radio backlights all work great). Fuses are fine as they were the first things I checked. Any help would be appreciated!
Thanks in advance for your help! Great site!
Brad
Old Dec 6, 2009 | 05:17 PM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
Our main Gauges (IPC) are actualy lit from the front by two UV (Blacklights) tubes on each side of the Cluster, Get your interior dark and turn your lights on, if you get your face close to the IPC and peer into each corner you should be able to see a faint Purple glow, that's the UV tubes... If you do not see that glow then your UV tubes are not working.
When the lights work intermittantly... do the gauges still function?
Have you checked for any codes by chance?
Old Dec 6, 2009 | 05:21 PM
canadian_Vette_guy
2nd Gear
Thanks tstar, will check that out. I wasn't able to check for codes but the off thing is that they work on and off. Are the tubes easy/costly to change?
Old Dec 6, 2009 | 05:22 PM
tstar's Avatar
tstar
I believe you have to get a whole IPC just to get the Tubes! Nice huh?
Do the gauges still function when the lights flick off??? It could be the plug on the back of the IPC is loose...
Tim
Old Dec 6, 2009 | 05:27 PM
canadian_Vette_guy
2nd Gear
Thanks for the info buddy. Yeah they always work. It seems that they are very dimm when they aren't working. How would I access the plug on the back of the IPC?
Brad
Old Dec 6, 2009 | 05:33 PM
tstar's Avatar
tstar
Use these, ignore the waterfall if you don't ahve a vert;
http://www.vetteessentials.com/instr...zel_howto.html
I doubt if it's the connector at the back of the IPC but hopefully you only have a loose connector at the UV power supply, here's it's connections;
Power (Thick Rainbow colored wires) and left UV tube harness (Blue and Gray wires);
Other side showing the UV tube, although it's dark;
Tim
Old Dec 6, 2009 | 05:45 PM
canadian_Vette_guy
2nd Gear
Thanks - How does that panel come out? Do have had by chev truck one out is it similar? Pull of the front trip then remove the hex screws?
Old Dec 6, 2009 | 05:53 PM
tstar's Avatar
tstar
Those instructions in the site I sent are the best I've seen;
Old Dec 6, 2009 | 06:08 PM
canadian_Vette_guy
2nd Gear
Thanks! That is helpful.....now I just have to wait for the spring to drive it again!
Old Dec 6, 2009 | 06:15 PM
tstar's Avatar
tstar
Yeah I just put mine in storage too...
Tim
Old Dec 6, 2009 | 11:18 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Tim
*****. I drive mine in 15" of snow with out issue.
Just kidding! New England shuts down Vette season right around the first part of Dec.
Bill
Old Dec 6, 2009 | 11:41 PM
racetchr's Avatar
racetchr
Old Dec 7, 2009 | 03:39 AM
tstar's Avatar
tstar
Bill
15" huh? Heck Bill, I never thought of slapping chains on the ole girl and using her to plow my freaking Driveway!
I actually got caught in a Blizzard on the way back form the New Header Install/Dyno session, it did prertty good.... Kinda!
Tim
Old Dec 11, 2009 | 11:23 AM
khblair's Avatar
khblair
Cruise-In 9-10 Veteran
St. Jude Donor '08-'09-'10
hey Tim
T2 (Tim) and i have redone (yet again) my custom gauges from Speedhut. it turns out that wiring it to the white white only succeeded in killing 2 batteries in 9 months and about 20 visits from AAA (real nice guys BTW )
anyway... we have finally rewired it to the light blue (which i think is what u said to wire it to in the beginning). now i remember why i made the managerial decision to use the white wire instead (it made it brighter).... i cant read anything on the gauges using the light blue wire. its too dark at night. it looks like a blue mushy glow - no numbers. i have the black faces, white letters and blue glow. after reading this thread im wondering if the blue with the black light is the cause of the problem.
your thoughts?
Old Dec 11, 2009 | 02:34 PM
tstar's Avatar
tstar
Hmmm I wouldn't think so BUT UVs can do some odd stuff for sure! The only real way to find out is to unplug the UV tubes from their power supply and see if that helps... You won't be able to see your needles though.
Your best bet if it still persists is to get Jeff (XtremeVette) to make you up a set of his custom faces for the Speedhut ones...
Tim
Old Dec 13, 2009 | 05:00 PM
khblair's Avatar
khblair
Tim
i met him at NCM.. might need to visit him
To Instrument panel backlight problem - Please help!
