COMP Rocker Trunion Install
But it seems pretty straight forward. Remove rockers, press the old trunions out, assemble and properly press in the new trunion setups, rotate the motor to TDC for #1, install the rocker to 22ft-lbs or torque, then rotate from there installing each corresponding rockers. After that, throw on the Valve covers, and call it good
Thanks again for checking though. You guys have been a huge help and probly saved me from making a mistake. Just glad to have the service manual coming in incase I need to do anything else in the future
What's the best way (In You Opinion) to find TDC on the #1 cylinder. I've read on different forums all sorts of methods involving straws to know the piston height & covering ones thumb over the spark plug hole to tell when its on the compression stroke as you should feel the pressure (opposed to an exhaust stroke)
A member on another forum said "Most accurate way is to use a tdc stop that screws into the # 1 spark plug hole. Once you screw in the stop slowly rotate (by hand) the engine until the piston comes up against the stop. mark the balancer. then rotate the engine in the opposite direction until it again hits the stops. mark the balance. Halfway between the two mark is tdc. Even if your balancer had slipped you can use the new mark as your zero".
So whats the verdict, anyone know the best way to find TDC on the #1 cylinder for a C6-Z06. Again obviously I'm a simple newb so I apologize for the simplistic question. Just would rather be safe than sorry and I know no better place to turn to for Z06 advice
Thanks for any help you can give me Guys!
Why do you want to find TDC so accurately? TDCish is close enough to re-install the rockers...
I would just take the plugs out for ease of turning, and get #1 piston roughly to the top with both valves shut. Roughly is good enough.
"i am surprised no one mentioned the intake closing exhaust opening method. Basically when you have the valve covers off look for when the intake starts to close after peak lift then adjust the the exhaust rocker to 22ft lbs. then when the exhaust begins to open the valve adjust the intake rocker to 22ft lbs. you do this for each cylinder. you can hand tighten each down at first so they work. then do the procedure."
- Does it really matter if I pop all the rockers off all at once, or should I go in sequence to when each is free of any tension/pressure?
http://www.youtube.com/watch?v=jJKMR..._order&list=UL
If you have the spark plug removed, you should be able to sue a flash light and see the top of the piston very close to the spark plug hole.
Then install the trunnion upgrade kit and reinstall all the rockers, then torque down the first 8 rockers per the Service manual, then rotate the crank 360 degrees and torque the other 8.
This is a good plan.You shouldn't loose too much of your mind on the the re-installation, though. I don't know if you've actually changed the bearings over yet, but if not, that's where I would pay the most attention. Its a fairly straight forward procedure, but if you don't pay attention to the details, you might get into trouble. If you understand everything discussed above, you shouldn't have any probs.
The movement shown in the video isnt what I was refering to, but was also present. If you draw a line between the pushrod end and the valve tip end, I could actually "roll" the arm around it. It would also twist around the bolt going through it. Big-time loosy-goosy
As far as rocker performance goes, I can't really tell any difference. This is more of a "quality improvement" mod, and as the original bearings were still doin the job, there was really no change to notice. The quality of these babies is much higher than the OEM pieces, IMHO. Its nice to know they're in there.
Good luck with your project!
After I installed the Comp Cams Trunnion Kit, the rocker arm side-to-side play went down to 0.010 to 0.015".
