turn signal bulb
Old Dec 12, 2009 | 09:12 AM
darts1's Avatar
darts1
3rd Gear
Default turn signal bulb
How do you replace the front turn signal bulb? I mean how do you get to it?
Thanks in advance,
Darts1
Old Dec 12, 2009 | 09:28 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
I have always raised the headlights so just the parking lights are on...remove the 3 screws securing the black headlight bezel and reach down to the light..twist pull
Old Dec 12, 2009 | 10:40 AM
rws.1's Avatar
rws.1
or get under the car, remove the plastic access panel about 5 self taping screws and reach up to change
or
if you have thin long arms sit in front of the Vette, push in and down on the accordian like black brake ducting to move it out of the way.
Then reach in and up find the bulb, pushin the detant, twist and remove the socket from the housing. pull the wiring to the opening, change the bulb and reverse.....
Old Dec 12, 2009 | 10:46 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I did the removal of the headlamp shroud and remove the hood position stop which allowed my arm to easily reach down there.
Old Dec 12, 2009 | 11:05 AM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
Here's a video that shows how you can change the turn signal bulb.
http://www.youtube.com/watch?v=BaUEoD2CH4k
Old Dec 12, 2009 | 11:44 AM
bucwheat's Avatar
bucwheat
Once you do it ,it seems easy the next time,as with most everything.
Old Dec 12, 2009 | 03:56 PM
DeeGee's Avatar
DeeGee
You'll get three suggestions
Go in through the brake ducts - not easy with a Z06 or if you have screens
Go in through the bottom by taking out the bottom panel
The one that works for me is:
Turn on the headlights and back off one position to kill the lights.
Unscrew the 3 small screws on the black plastic housing around the headlight. Gently pull the housing clear. Reach down around the headlight unit and release the bulb holder. It comes out by turning the bulb holder a ¼ turn counter clockwise but it has a plastic clip which you need to squeeze to release it. Here’s how the bulb fits into the lamp unit. The DRL bulb is the lower of the two.
Here’s the light socket. This one’s after market but it gives you the idea. You can see the clip you need to squeeze.
Change the bulb. It’s a push fit into the lamp holder. Push it home firmly but don’t handle the glass. Use latex gloves if you have them. Reseat the bulb holder and turn clockwise until it clicks back in place. Put the plastic headlight housing back in place making sure to locate the small plastic tab in the bracket on the headlamp cover. Replace the 3 screws and close the lights.
It’s a 10 minute job. Some guys have had the lights close if they’ve taken a while to do the fix. If you’re worried about that, disconnect the battery once the lights are up.
The bulb is a 4157NA
Some guys with big arms remove the hood adjusting screw for better access. Guys with even bigger arms have had to take off the headlight cover. Four torx screws (2 back, 1 each side). Take the back ones off first with the lamps down. Raise the lights and take the side ones out.
Old Dec 12, 2009 | 05:05 PM
99XTC's Avatar
99XTC
what kind of bulbs do you need? I went to autozone, but the ones they got from the computer did not fit (same when I went to the dealership).
Old Dec 12, 2009 | 05:38 PM
DeeGee's Avatar
DeeGee
The bulb is a 4157NA A 3157NA will work also
Old Jan 28, 2010 | 02:53 PM
Castrellon's Avatar
Castrellon
Default Doh! Help!
Tried this 2 minute fix and broke the white plastic thing that retains the bulb to the lamp shroud.
Is it just called a retainer?
Can I get this from a local body shop supplier (ie: after market)
Is it dealer item only?
Old Jan 30, 2010 | 09:16 PM
Castrellon's Avatar
Castrellon
Old Jan 31, 2010 | 12:26 AM
jrose7004's Avatar
jrose7004
I use the bottom hatch.
Old Jan 31, 2010 | 03:12 PM
lionelhutz's Avatar
lionelhutz
That part is on the socket? You would have to replace the whole socket to fix it. You should be able to find one at any decent car parts store.
Peter
Old Jan 31, 2010 | 04:00 PM
Castrellon's Avatar
Castrellon
Peter
Thanks. I'll try O'rilley and Autozone.
To turn signal bulb
