How much does the diff weigh?
Old Dec 12, 2009 | 02:47 PM
Its_Go_Time's Avatar
Its_Go_Time
Default How much does the diff weigh?
I'm changing out the output shafts, and am mulling over how best to pull the differential. If I lower the driveline at the rear and pull the diff straight off, am I in for a big surprise? I have a rig I built to remove the entire driveline, but I'd like to avoid that if possible.
Old Dec 12, 2009 | 03:23 PM
Darion's Avatar
Darion
Shipping weight for the rear diff is about 75lbs as I remember.
Darion
Old Dec 12, 2009 | 04:04 PM
bumble-z's Avatar
bumble-z
There's plenty of previous info on how to do this proceedure. Use the "search" button in the tech section. You're main concern an regarding weight is lowering and removing the rear cradle. Once this is done and diff fluid is removed, you'll be able to pull the diff by hand, no problem. Ask me how I know. Good luck.
Old Dec 12, 2009 | 04:21 PM
Its_Go_Time
bumble-z, the cradle is long gone, so no concern there. You're telling me that when i slide the diff of the transmission shaft, its NOT going to crush my head like a pumpkin? Could you give me an edumacated guess of its weight?
Old Dec 12, 2009 | 04:24 PM
Its_Go_Time
Darion
THANKS! didn't see ur reply! I should be able to balance that on my jack no problem.
Old Dec 12, 2009 | 05:47 PM
bumble-z's Avatar
bumble-z
Just came from my garage. The old shipping container that my Racing H/D 3:90 diff came in last Dec weighed 83 lbbs. I'd say w/ all the cushing cardboard , H/D plastic shipping container and new bottles of Red line fluids & additives, weighed at least 10 lbs by themself! So I'd think that rear diff weighs arond 68- 70 lbs max. I used the handy H/Freight 450 lb., capacity trans jack (scissor) part # 39178 lifts from 7 1/4" -23 `1/4" You can raise and lower by using a 1/2" drive rachet or like I did with my i/2" impact. The top of the jack can be angled, which is nice for this job. And it's real light too!. Check it out. In fact my old 3:43 diff is still resting on it. Have fun,lol.
Old Dec 12, 2009 | 06:27 PM
Its_Go_Time
Thanks for taking the time to check!
Old Dec 12, 2009 | 08:10 PM
homervet's Avatar
homervet
76 lbs in the box (cardboard)..70 lbs should be about right.
Old Dec 13, 2009 | 09:59 AM
craig04c5's Avatar
craig04c5
Enough to crush my fingers. Was helping EG do mine and I though I could support it. I am not weak so it surprised me. Not that big but 75-80 lbs seems about right.
Old Dec 13, 2009 | 10:01 PM
Its_Go_Time
Default And the right answer is...
Thanks to everyone for your help, but you were all wrong.
Old Dec 14, 2009 | 02:29 PM
MikeV's Avatar
MikeV
Remember not to lower the torque tube to far or you will impact the fire wall with the engine.
Mike V
To How much does the diff weigh?
