Possible slave cylinder problem
Old Dec 13, 2009 | 11:56 PM
jobberone's Avatar
jobberone
jobberone
Originally Posted by Mark C5
The system is not vented. If you remove your cap you will find a rubber diaphragm that expands as the fluid level drops. The diaphragm seals off the system from outside air and prevents an air gap on top of the fluid level. The vent in the cap is there to allow the diaphragm to expand. If you were going to get water from condensation, it would gather in the diaphragm but never come in contact with the hydraulic fluid.
There is water vapor in air. The system is not under a vacuum. Water will get into the fluid via contact with the air. The diaphragm will not keep it from having a fluid/air interface.
Old Dec 14, 2009 | 11:02 AM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
The system does operate under vacuum. Every time you push the clutch pedal fluid is forced from the reservoir into the slave cylinder lowering the fluid level in the reservoir. The diaphragm is drawn down by vacuum to prevent an air space as would occur in a vented system. The upper side of the diaphragm is vented to allow the movement but the system remains sealed from outside air.
When you install the diaphragm it displaces the air in the reservoir. Take yours out and look at it. You will see that the reservoir side is completely wet with hydraulic fluid. If it is not you need to fill the system, the fluid level is low.
Old Dec 15, 2009 | 02:09 PM
Bull_in_a_china_shop's Avatar
Not a bad idea to update the hydraulics either way. For ease of access the master is behind the front wheel well, but most likely its the slave and or the pilot bearing. When I munched my bearing it grinded in and out of gear all kinds of weirdness. Learned my lesson to ALWAYS put in a pilot when the car is apart.
Old Dec 15, 2009 | 02:12 PM
and FWIW they are all on sale ;-)
http://forums.corvetteforum.com/c5-t...-specials.html
Old Dec 15, 2009 | 10:59 PM
jobberone's Avatar
jobberone
jobberone
It is not a vacuum. Air comes into contact with the top of the fluid. Air doesn't get into the fluid though. We'll have to agree to disagree. Air makes contact with the fluid. It's not a major problem.
Old Dec 18, 2009 | 05:26 PM
jobberone's Avatar
jobberone
jobberone
I bought a pilot bearing with the slave. Thanks for all the kind responses all. We're half way through getting to the slave. We're having loads of fun, my son and I.
