LS1 Waterpump
Old Dec 15, 2009 | 11:50 AM
Paladin62's Avatar
Paladin62
Default LS1 Waterpump
Walked out in the garage this morning and there is a puddle of water coming from under the C5. It's got 110k on it so I wouldn't be surprised if it's the waterpump.
I did some calling around for pricing - Boy what variations!
Dealership $327 (discounted 20%) New
Local Corvette parts house $298 (discounted 7%) New
NAPA $179 New "TFW"
Oriely $181 New "Master Pro"
Oriely $150 Rebuilt "Cordone"
Autozone $135 Rebuilt "Duralast"
I won't buy a rebuilt one, but would like to hear opinions on the other three (the Dealership and parts house are both Delco). Does anyone have experience with the TFW and Master Pro brands?
Clay
Old Dec 15, 2009 | 12:17 PM
vettenuts's Avatar
vettenuts
Have you tried Gene Culley or SDPC? I prefer either GM or if aftermarket something that will provide better performance.
Old Dec 15, 2009 | 12:21 PM
lucky131969's Avatar
lucky131969
Looks like $265 from GMpartshouse.com. Yes it's more than autozone, but if it lasts another 100K+, it seems like a wise investment.
Old Dec 15, 2009 | 12:23 PM
LoneStarFRC's Avatar
LoneStarFRC
NAPA $179 New "TFW"
Clay
No I don't, however Rock-Auto has new Delco's for $135.89
Old Dec 15, 2009 | 12:27 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Clay
I replaced the pump on my 98 with a CORDONE and it worked fantastic! Very straight forward repair. Good time to renew the coolant and if your a fan of a cooler thermostat, now’s a good time to get one of those also. I would get a 178-180 deg stat.
There are THREE different pumps early 97-98 mid year 99-2003 and late 2004
When I replaced mine I before I changed the pump, I flushed ALL the coolant out of the engine until I got clean water out of the cooling system. (If it's winter in your area, you may not be able to do that)
You could remove the pump and use a wet and dry vac and suck as much old coolant out of the block as you can from the block pump flange openings. A lot will come out.
On the refill, I use a complete gallon of DEXCOOL and then dilute to the correct freeze point with distilled water.
BC
Old Dec 15, 2009 | 04:19 PM
Paladin62's Avatar
Paladin62
Rock Auto ROCKS!! I didn't see where the unit was "new" Did I miss that?
Old Dec 15, 2009 | 10:18 PM
LoneStarFRC
No core charge is a clue plus it's not in the decription as a reman unit. If in doubt, call Rock Auto to confirm.
HTH
Old Dec 15, 2009 | 10:50 PM
vsocks1's Avatar
vsocks1
I have one that came off my 03 LS6 that I replaced with an EWP. It only had 10,000 miles on it and I would be willing to part with it if interested!
Old Dec 15, 2009 | 11:27 PM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
If you buy from them do a google search for Rockauto promo codes. They always have a 5% off code on the net.
Old Dec 16, 2009 | 02:55 AM
soggysailor's Avatar
soggysailor
I may get flamed, but I just installed the Duralast one from Autozone. Its got a lifetime guarantee and so far performs fine!
Also, if your bent on spending alot on a new water pump look at the LS3. They made a few changes and looked interesting.
Old Dec 16, 2009 | 03:08 AM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
I don't know why people are so afraid of remanufactured parts either....They generally get more personal attention and quality control than brand new parts.
The extra cost of buying new usually means your paying for a new casting (housing), the one part of a water pump that rarely fails or becomes unserviceable.
Old Dec 16, 2009 | 07:37 AM
LoneStarFRC
In my previous life I worked in aftermarket auto parts for a number of years. The quality of a rebuilt (or the sometimes more popular marketing term: "remanufactured") part is STRICTLY dependant on the company selling/rebuilding them, so unless your familiar with which ones are crap, i.e. high return rates, it's crap shoot for the average Joe. I personally don't recall EVER having a return (due to a defect) item that was new, vs "rolling the dice" on the various rebuilders.
Having said that, the one rebuilder company that we had the fewest returns on was Delco. Very rare.
Remember too: the labor to swap a defective part is the same the second time around, and rebuilders do NOT cover labor nor towing charges if you get stranded along side the road.
Old Dec 16, 2009 | 06:31 PM
2079's Avatar
2079
Great advise.
Old Dec 21, 2009 | 12:15 AM
Paladin62's Avatar
Paladin62
OK the pump was shot...pulled it off and drove to the closest parts store (Autozone). The "rebuilt" Duralast pump turned out to be new...price was $135.00 with a lifetime warranty...went on like warm butter...the car is my wife's "shut up" car and I don't show it...so OEM is not a factor...Thanks for all the advise.
Old Dec 29, 2009 | 01:20 PM
Paladin62's Avatar
Paladin62
Since I changed the pump, my heater is not putting out warm air. The engine is running cooler now than it did before the waterpump replacement (around 190). When I did the replacement, I allowed the engine to run for 15 - 20 minutes with the resovoir fill cap off to let the air out. I used the OEM thermostat. I also noticed that the air on the passenger side is warmer than the air on the drivers side. Strange!!
Any ideas?
Old Jan 5, 2010 | 01:32 AM
Paladin62's Avatar
Paladin62
I read the post of "1moretime" of his heater problem and it was suggested that he check the vaccumm lines under the battery...I haven't looked but doubt that could be my problem. My heater was working fine before the waterpump replacement... I have found that on occassion if you turn the car off and restart, I get heat on both sides...Still looking for a solution...
Old Feb 26, 2010 | 07:45 PM
postwhore's Avatar
postwhore
I just paid 133.99 for a New Bosch pump at Pep Boys.
To LS1 Waterpump
Old Feb 26, 2010 | 08:34 PM
NemesisC5's Avatar
NemesisC5
Will the LS3 water pump fit on GEN 3 LS1/2/6 engines???
Old Feb 26, 2010 | 09:08 PM
DIXZ's Avatar
DIXZ
It must because I am using my LS6 water pump on my LS3 engine.
Old Feb 27, 2010 | 12:47 PM
NemesisC5's Avatar
NemesisC5
Does the LS3 unit have any benefits over the LS1/2/6 units? Increased flow, etc...??
