Another CAM Thread
Old Dec 16, 2009 | 06:10 PM
SargeZ06's Avatar
SargeZ06
Default Another CAM Thread
Okay I have an 02 Z06 with 1 7/8 Kooks, Off-road X-Pipe (no Cats), Ti exhaust, Stinger CAI, Monster 3.5 Clutch w/lightweight flywheel, and a tune, stock heads, TB, and Intake. Cut-outs to be added later.
Dynos right at 400RWHP.
I want the nastiest CAM I can get without fly-cutting the pistons.
It's not a daily driver and I'm not concerned with drive-ability. Its to have one hell of a good time in it when I do drive it.
I want children to run, old ladies to scream, and pregnant woman to lactate.
Is there anything out there that will get me in the 460RWHP range? Power in the 3500-6500 range.
Whiplash II, TRex, G5X4, G6X3...
TIA
Sarge
Old Dec 16, 2009 | 06:37 PM
Roostertail's Avatar
Roostertail
St. Jude Donor '06
I would look into something from England Green
http://forums.corvetteforum.com/c5-t...whp-mojo1.html
Nick
Old Dec 16, 2009 | 07:23 PM
frcslave's Avatar
frcslave
You may want to look into a custom grind as well as the typical off the shelf cams. To make it to the 460 rwhp range you will probably need to invest in a FAST 90/90 set-up but who knows what could happen. I am running a custom cam motion 238/242 and it is pretty nasty - really kicks in above 3500 and the idle sounds great on a 112* lsa. Good luck!
Old Dec 16, 2009 | 07:38 PM
SargeZ06's Avatar
SargeZ06
Yeah I'm probably going to get Spinmonster to do port on my Intake and TB. Maybe switch to a ported LS2 instake and TB.
Old Dec 16, 2009 | 09:22 PM
Corvette Don's Avatar
Corvette Don
Prob going to want to be around a MS3 size cam with a 112 LSA (MAYBE could go 111 but I doubt it) without flycutting. I had to flycut on my set up below.
Old Dec 16, 2009 | 11:35 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
TIA
Sarge
CAI, longtubes, free flowing catbacks, heads, FAST 92/90 and a decent sized cam will get you there, no problem. Driveability is all in the tune
Old Dec 16, 2009 | 11:56 PM
0331MARINE's Avatar
0331MARINE
From: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
I have the MS3 on a 112 LSA and it has a very very mean idle to it and very good power and I didnt have to fly cut my pistons. Good luck with the search
Old Dec 17, 2009 | 06:46 AM
legman's Avatar
legman
Nick
...Whiplash 2 with cut-outs......
Old Dec 17, 2009 | 09:23 AM
Independent1's Avatar
Independent1
St. Jude Donor '08
a G5X3 cam on a 114 should do the trick.
I have one in my car. Real attention getter.
To Another CAM Thread
