LS1 blocks question
Old Dec 18, 2009 | 09:00 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Default LS1 blocks question
is there a difference in the blocks of the various LS1 variatons? Does the LS6 block differ?
Old Dec 18, 2009 | 09:16 PM
vettenuts's Avatar
vettenuts
LS6 block is different and includes better bay to bay breathing, a stronger block design. Later LS1 and LS6 blocks have different liners that allow 0.010" over bore, earlier blocks do not.
Note that some LS1 engines use the LS6 block, I know mine does as I checked the casting number last time the heads were off.
Old Dec 19, 2009 | 10:45 PM
ragtopws6's Avatar
ragtopws6
The LS6 blocks have a casting # 12561168 just below the driver's side head toward the back. C5 Vettes started using them on LS1's I think around 2002.
Old Dec 19, 2009 | 10:47 PM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
what is "bay breathing"?
Old Dec 19, 2009 | 11:01 PM
ragtopws6's Avatar
ragtopws6
Since the LS series have a deep skirt block design, the 2 cylinders (4 chambers) share a "chamber" below the piston. This is where the crank spins the connecting rods. When the engine is running, the 4 chambers build pressure from pistons moving up and down. The LS6 blocks have a "window" between the chambers to equalize the pressure created by the piston movement.
Old Dec 20, 2009 | 07:26 AM
AU N EGL's Avatar
AU N EGL
IIRC the LS6 blocks have better oiling galleys and stronger head studs over the original LS1 blocks,
all the blocks now are LS6 blocks, even though over on LS1tech, they still call the blocks LS1 blocks.
Old Dec 20, 2009 | 09:31 AM
JVetthead's Avatar
JVetthead
I believe also the LS1-6 front cover and valley cover are different than LS2-3-7
To LS1 blocks question
