Dropped a key inside battery tray.... help!!!
Old Dec 20, 2009 | 08:23 AM
evil chevy's Avatar
evil chevy
Default Dropped a key inside battery tray.... help!!!
Was trying to replace my battery on the Z06, when I was unscrewing the bolt that block the battery in place the socket and extension jump from the screw and fell off in the hole on the side of the battery and the fuse box....
looked at the way to get it back but doesn't look easy at all.
Does any one made the same mistake and knows how to access it???
Old Dec 20, 2009 | 08:43 AM
japc5's Avatar
japc5
It's happened to me, there is a good chance you can get to it if you remove the battery and battery tray. If it is further down then remove the front wheel and the PCM access panel.
Have fun!!
Old Dec 20, 2009 | 08:59 AM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
Have you try a magnetic fishing tool?
Old Dec 20, 2009 | 02:27 PM
TEXHAWK0's Avatar
TEXHAWK0
It might be easier to just remove the inner fender liner and get it the first time.
Old Dec 20, 2009 | 02:33 PM
bobby777's Avatar
bobby777
Leave it for the future owner
Old Dec 20, 2009 | 03:37 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Theres an access hole in the fender. Thats the best way;
Old Dec 21, 2009 | 07:31 AM
TurboTnZ06's Avatar
TurboTnZ06
That reminds me, that's where I left that socket
Old Dec 21, 2009 | 08:45 AM
torkman15's Avatar
torkman15
X2 If it went in easy it'll come out easy with a magnet on a stick. Good luck.
Old Dec 21, 2009 | 09:16 AM
jrose7004's Avatar
jrose7004
That was my thought too.
Old Dec 21, 2009 | 07:12 PM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Listen to Bill!
Old Dec 22, 2009 | 12:30 AM
4DRUSH's Avatar
4DRUSH
Don't forget to get your key out also.
Old Dec 22, 2009 | 01:53 PM
ALLEGRO's Avatar
ALLEGRO
Sears (and others) sell a lighted magnet light that is retractable. It has gotten me out of numerous jams such as yours.
Good Luck
Old Dec 22, 2009 | 02:42 PM
Eric D's Avatar
Eric D
Good Luck
Cool!! Does the light help the magnet see what it needs to pickup?
Old Dec 22, 2009 | 03:35 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
I have dropped 27 items down there, x4 13mm bolts to remove the tray, it always sits on the frame rail
1/4 air ratchet works fast
you can throw the magnet about 20 feet after you spend 30 minutes fishing
re: Bill C's post, good info, a good fist tap on the bottom of that closeout panel will indicate an item is lurking there, you hear the tap
Old Dec 22, 2009 | 06:52 PM
taegee2's Avatar
taegee2
I lost a socket there too when I replaced my battery. I tried the magnet extension tool but it was hard to see. I removed the battery tray (just remove the bolts) and got it out.
Old Dec 22, 2009 | 08:39 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
remove the battery and the tray.. its very simple...
Old Dec 23, 2009 | 09:51 AM
87SAM's Avatar
87SAM
The OP hasn't been back, maybe now he has his hand stuck!
To Dropped a key inside battery tray.... help!!!
Old Dec 23, 2009 | 10:59 AM
Quicksilver Vert 01
The lighted magnet should help locate the stuck hand too.
Old Dec 23, 2009 | 10:23 PM
texanz06's Avatar
texanz06
Learned the hard way that whenever I'm messing around with the battery to always stuff shop rags around the sides of the mounting plate and in the hole in the bottom of it, then pull 'em out once the battery is mounted!
Old Dec 24, 2009 | 10:09 AM
bucwheat's Avatar
bucwheat
Yesterday I was replacing the clock light in my Accord and a tiny screw fell into the dash,thought it was gone forever,got a flexible shaft magnet,stuck it in and got it the first try,wonderful things ,those magnets.
