A/C Problem!!!!! Help!!!!!
Old Dec 20, 2009 | 06:46 PM
stjs45's Avatar
stjs45
Default A/C Problem!!!!! Help!!!!!
I have and 02 auto with dual climate control. When i put the a/c at full blast or for that matter at any cold temp, the passenger side works but my driver side doesnt. It seems like the heater is on. I havent check the freon yet. Will do first thing in the morning, but the passengers side its freezing cold. WTF?? Thanx
Old Dec 20, 2009 | 06:52 PM
lucky131969's Avatar
lucky131969
Below is one of many threads on this topic....if you do search:
http://forums.corvetteforum.com/c5-t...side-only.html
Old Dec 20, 2009 | 07:48 PM
97C5owner's Avatar
97C5owner
80% probability you are just low on freon. Check it first. 20% probability your blend doors need to be reindexed. I've had this problem on 2 of my C5's. Low freon was the culprit in both.
I know it sounds weird, but check your level. I'll bet you a beer its low.
After filling to factory specs- pull the relays and fuses to reset- and you're done. Easy fix.
To A/C Problem!!!!! Help!!!!!
