Help. Timing Chain Broke. What next?
Old Dec 25, 2009 | 04:48 PM
billy25us's Avatar
billy25us
Default Help. Timing Chain Broke. What next? Update!
While on the track at about 100mph in 4th my timing chain broke at the time the car just died and had no idea what happened. The car is a 00 ls1 vette. Got home and determined it was the chain . I have the old chain off and I bought a c5r chain from katack. I was hoping I would be the luckiest sob in the world and not have any other damage.
My questions are can I put the car back together and check compression to determine any valve ,piston or other damage or should I go ahead and take off the heads to check. And what are the chances of getting away with only replacing the chain.
Just got the chance to dive back in. After the #2 cylinder showed zero compression did not have to go any farther with the compression test. Pulled heads and it appears that at least 4 intake and 4 exhuast valves were bent. I had a scar in the top of each piston that was hit but not very deep. Should be able to buff out. So the block was fine . The heads are at the machine shop now and they appeared to be fine except for the bent valves.
Old Dec 25, 2009 | 04:55 PM
dougbfresh's Avatar
dougbfresh
Bet you have damage, at least valve train (bent push rods). Guess it wouldn't hurt to replace the chain and check compression but don't expect miracles.
Old Dec 25, 2009 | 08:53 PM
lucky131969's Avatar
lucky131969
Considering the conditions under which you broke the chain, I think pulling the heads for inspection of the valves and pistons is mandatory.
Old Dec 26, 2009 | 09:11 AM
vettenuts's Avatar
vettenuts
I would be really surprised to find out that only the chain broke. First step I would take is pull the valve covers and rocker arms. Put a straight edge across the valve stems and see if the are all in line as bent valves will not come up all the way. I would plan on pulling the heads though. The chances of not bending a valve (likely more than one) under those conditions are close to zero. I think you will be a "lucky sob" if the pistons are OK.
Old Dec 26, 2009 | 09:35 AM
ILM-Express's Avatar
ILM-Express
MFIC
Old Dec 26, 2009 | 09:37 AM
99 vett babycar's Avatar
99 vett babycar
Old Dec 26, 2009 | 09:41 AM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
lucky would be an understatement if you only broke the chain.
you should take it all down and see what other problems there might be. I would suspect rod(s) and valve(s) at the least. If the valve is messed the piston(s) are probably going to need to be replaced. Hopefully the heads didnt get hit.
After I broke my timing chain a few years ago we did alot of research in this area. Some times we found it was the timing chain, but many times we found it was some other part of the valve train that actually was the cause and the timing chain just happen to go too.
Old Dec 26, 2009 | 11:07 PM
aweil's Avatar
aweil
pull the rockers and leak the motor down.
Old Dec 27, 2009 | 04:19 PM
corvettebob1's Avatar
corvettebob1
Zero
Old Jan 7, 2010 | 06:04 PM
billy25us's Avatar
billy25us
Just updated the post. Looks as if I got away with only bending a few valves.
Old Jan 7, 2010 | 06:21 PM
ZZOOM06's Avatar
ZZOOM06
Make lemonade from the lemons, get the heads milled a bit to up the compression, have them ported and definitely put some new springs and valve seals on them. Better change the pushrods too.
Good luck!
Jimbo
Old Jan 7, 2010 | 06:52 PM
GeorgeZNJ's Avatar
GeorgeZNJ
St. Jude Donor '08-'09
I've broken two different chains throughout the life of my 02 Z so far. Both times the collateral damage totaled the engines. Pull the heads look for broken valves, I had valve tops embedded into the heads, broken pistons with the rings in pieces everywhere and holes in the block you could put you fist in.
I hope you have better luck then I did. BTW, both times this happened I was in 4th gear on a track around 140-147mph. We tend to think that the on the throttle/off the throttle/ on again allows the chain to flex enough to cause the breakage. Look into the chain tensioner/flex stops that the LS7's have. I believe the ls6 blocks already have the threaded holes for mounting.
Old Jan 7, 2010 | 07:33 PM
Paul 75 L82's Avatar
Paul 75 L82
That some good info.
Old Jan 7, 2010 | 08:00 PM
vettenuts's Avatar
vettenuts
Yes, they have the holes. Unfortunately, the timing chain damper is no longer made for the LS1/LS6 blocks except for later 04 blocks where the hole spacing was changed and the LS2 timing chain damper will fit. There is a known harmonic issue with the timing chain and hence the reason the damper was developed.
Old Jan 8, 2010 | 01:22 AM
MDR1970's Avatar
MDR1970
I wish someone would make an ls1 dampner, they would sell a ton of them!!
Old Jan 10, 2010 | 09:58 AM
billy25us's Avatar
billy25us
This is a ls1 block with ls6 heads. Is there a dampner made for a ls1block. Plus got a call from the machine shop. Heads are fine but bent all the valves except 4.
Old Jan 10, 2010 | 09:27 PM
wayneosan's Avatar
wayneosan
4th Gear
Default lucked out
We just had a timing chain start loosing all the links. Found this out when, car DROVE into bay for plugs and oil change. When I removed the drain plug, out came a train of rollers and links stuck to the drain plug.
No, the chain never broke.
That's luck.
To Help. Timing Chain Broke. What next?
Old Jan 11, 2010 | 06:45 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
That's luck.
If there was a link connected to your oil drain plug the chain must have broken. You can't loose a link of the chain and the chain still be intact. I bet the rollers are from your rocker arms and not the timing chain.
Old Jan 11, 2010 | 07:10 PM
lucky131969
That's luck.
Please post pics of the links you pulled from the oil pan.
Old Jan 11, 2010 | 11:32 PM
wayneosan's Avatar
wayneosan
4th Gear
Default pics requested
this is what I found.
TIC TOC..
this is where it came from.....
and if you still don't believe.....here's a pic of the sloppy chain on the engine. still in disbelief. Why do these do this again?
chalk this one up to; "why you don't........"
