upgrading to LS6 - need permatex
Old Dec 26, 2009 | 11:10 PM
futuretech's Avatar
futuretech
Default upgrading to LS6 - need permatex
I know I need locktite for the bolts. Do I need any sealant around the used OEM manifold gaskets?
Old Dec 26, 2009 | 11:28 PM
aweil's Avatar
aweil
I didn't use loctite or sealant on any of my LSx builds.
Old Dec 26, 2009 | 11:39 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
Remember me?
Okay... on factory gaskets (or the aftermarket Fel-Pro rubber gaskets) NO sealant should be used. This is new technology, forget the gen I and gen II engines.
The intake bolts don't need loc-tite. The tension of the bolt heads when torqued against the plastic manifold is all they need.
Trust me.
Old Dec 27, 2009 | 08:59 AM
vettenuts's Avatar
vettenuts
I think they call out the loctite for sealing as well since the bolts go into an area of the motor where there is oil and oil vapor. Having said that, I have had mine on and off so many times I don't bother with loctite any more and have had no issues. For the intake gaskets, if the car has a lot of miles you may want to replace them as they do take a set and they will be filled with dirt.
Old Dec 27, 2009 | 10:05 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If the gaskets look good and sit ABOVE the manifold flange, they will seal without sealant. I have never used locktite on the manifold bolts and have never had an issue.
BC
Old Dec 27, 2009 | 12:00 PM
futuretech's Avatar
futuretech
Thanks guys.
Old Dec 27, 2009 | 12:01 PM
futuretech's Avatar
futuretech
Originally Posted by ~Joshua
Remember me?
Trust me.
If I didn't know better I'd think you were following me. hehe
To upgrading to LS6 - need permatex
