Considering Engine swap
Old Dec 28, 2009 | 08:56 PM
TurboBerserker's Avatar
TurboBerserker
You'll want to keep your fuel system. You will want to upgrade to the 411 (99-02 replacement) PCM however.
I'd do a nice LQ4 block with LQ9/LS2 pistons and rods and some 243s for a cheap go fast NA engine.
Old Dec 28, 2009 | 09:04 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
I'm not very familier with the LQ series engines. How do they differ from the the LS engines?
Old Dec 28, 2009 | 09:16 PM
froman's Avatar
froman
iron block right? good for boost. BTW, Franks rules
Old Dec 28, 2009 | 10:39 PM
Tech's Avatar
Tech
Originally Posted by TheRadioFlyer
I'm hovering around 320 rwhp (can't remember tq numbers). other than intake cam and heads, Is there any significant block difference betweeen an 02+ LS6 and my 97 LS1?
What mods are done to your car? There were definitely differences, but none of which affect RWHP. You'll want to keep your redline sub 6500 RPMs unless you upgrade your rod bolts. Oil pump also has to be replaced when the cam goes in.
Old Dec 28, 2009 | 11:08 PM
83Camaro's Avatar
83Camaro
what transmssion did you have? what happened to it?
Old Dec 28, 2009 | 11:12 PM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Intake: vararam, aftermarket MAF housing, power duct, Ported TB, LS6 intake
Exhaust: SSAC headers, High flow cats, WCC 2x2 X pipe and borla stingers
Engine: 1.8 YT roller rockers
Tune: Custom tune w/ HP tuners
Stock A4: My planitary gear exploded....not sure what that means, but i had forward 1 and 2....and that was it. I got it re-built with heavy duty components and a shift kit. Franks says it's pretty much bulletproof to anything i'm going to do in the road that's remotely legal.
Old Dec 29, 2009 | 08:37 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
L6 block is better designed than the older 97 - 99 blocks.
The link that independent1 gave you to my old motor was putting down around 525 rwhp using a maggie. It has a LPE blower cam and only 22K miles on it. No oil consumption problems. Motor runs strong. You would be all set to go to the next stage if you wanted to install a maggie.
Old Dec 29, 2009 | 10:30 AM
SaberD's Avatar
SaberD
the rod bolts are different in the ls6 block. the newer engines can rev higher. there is another difference with some additional holes made for oil passages too. i read that its another factor that allows it to rev higher. i have no idea how it works though.
Old Dec 29, 2009 | 12:31 PM
TurboBerserker
The LQs are iron 6.0L blocks that cam in the trucks. The LQ4 used a dished piston and cam stock with 9.5:1 CR, the LQ9 was 10.1:1 with flat tops and stronger rods.
They are boost monsters. I've seen several LQ based strokers hit over 1000 rwhp holding 24+ psi. The worlds fastest GenIII truck (turned around a 8.8 1/4 mile on a shake down run and is not completely tuned yet) is an LQ block (but to be fair, it's half hard-blocked). Parish8 ran low 10s (10.04 I think) 3 years ago with an LQ block stroker (408ci) and lots of boost. I think he was at 1080ish rwhp and 1175ish rwtq.
They are a very common truck engine choice -- easy to stroke, high strength, lots of power potential. You can pick up a brand new block for something like $700 I think, and can find a lot of deals in the used market (check out your local craigslist and performancetrucks.net).
Old Dec 29, 2009 | 12:53 PM
fsuforever's Avatar
fsuforever
,Also look @ the weight of the Truck vs the c5 corvette ,not to mention the aerodynamics of the c5 ,can u say BEAST!! Ya u can buy a Brand New Lq9 block from scogginDickey for 700.00 ,this is where i bought mine
Old Dec 29, 2009 | 01:14 PM
TurboBerserker
Yep -- Parish8's truck was 4800 for the 10.04 run. The 8.8 truck was in the 4300 range I think. Either setup in a vette = rocketship that eats tires for breakfast lol.
Old Dec 29, 2009 | 02:07 PM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
did Parish have a blue 03+ single cab truck? i think i'm thinking of the same person
Old Dec 29, 2009 | 02:21 PM
  #33
TurboBerserker
Yep, among other rides. Right now he's running a turbo G8.
Old Apr 26, 2010 | 11:38 PM
  #34
TooMch's Avatar
TooMch
What did you ever do?
Old Apr 26, 2010 | 11:42 PM
  #35
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Decided to save the $$ for a C6
I figure i'll just start over. Get an LS2 and throw a KB supercharger on it and be done with the powerplant.
Old Apr 27, 2010 | 01:11 AM
  #36
99blancoss's Avatar
099blancoss
Former Vendor
St. Jude Donor '10-'11-'12
Why not spend $3400 on a proper bottom end 383 and put it back together as is. An LS2 isn't forged and if your going to do it, you might as well do it right. I know people run low boost on stock bottom ends but it isn't optimal. Then having to run a meth kit. Why not just do it right from scratch and then not worry about things.
We can build it for low compression and then you can boost it when your ready to or for 7k we can build you a long block with AFR 205's on top and make a solid machine out of it.
Old Apr 27, 2010 | 04:52 AM
  #37
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
It's more based on: i don't want to spend that kind of $$ on this particular 13 y/o Car. It's developing a few other "quirk" problems that are just annoying and expensive.
Old Apr 27, 2010 | 07:42 AM
  #38
AU N EGL's Avatar
AU N EGL
If i decided to stay N/A does thee LS6 option look better?
YES.
many ppl have had blown up engines, bad choices on engine mods which they will not admit, and just said F it and put in an LS6 crate and had it tuned.
then again
Sounds really good
Old Apr 27, 2010 | 11:23 AM
  #39
99blancoss's Avatar
099blancoss
Former Vendor
Ahh, yes there is that side of it as well. Age does bring on some more opportunities for maintenance
