T1 swaybar installation problem
Old Dec 29, 2009 | 05:03 AM
C5_Z06's Avatar
C5_Z06
Default T1 swaybar installation problem
I've installed the T1 swaybars and bushings on my 2002 Z06. There is an interference issue where the front bar is touching the A/C pipe in the lower right corner of the radiator. Is this a common issue? I noticed the stock bars was also very close to that pipe, but with the larger T1 bar they collide. The bar is centered. Car has the T1 springs and shocks if that matters. Ride height set to stock level.
Old Dec 29, 2009 | 07:47 AM
Ms Eliz's Avatar
Ms Eliz
Ask this question in the Forums: General Corvette > Autocrossing-Road Racing section. Real expertise there!
Ms Eliz
Old Dec 29, 2009 | 08:12 AM
AU N EGL's Avatar
AU N EGL
Here is mine
Old Dec 29, 2009 | 08:19 AM
C5_Z06's Avatar
C5_Z06
Ms Eliz
I think most of the guys there have removed the A/C? Since the T1 bars seem to be a popular update I was hopeing somebody here could have been in same situation.
Originally Posted by AU N EGL
Here is mine
Thanks, but the A/C pipe wasn't visable on the pics.
Old Dec 29, 2009 | 04:48 PM
69's Avatar
69
Cruise-In VI Veteran
[QUOTE=C5_Z06;1572570204]I've installed the T1 swaybars and bushings on my 2002 Z06. There is an interference issue where the front bar is touching the A/C pipe in the lower right corner of the radiator. Is this a common issue? I noticed the stock bars was also very close to that pipe, but with the larger T1 bar they collide. The bar is centered. Car has the T1 springs and shocks if that matters. Ride height set to stock level.
From your photo's I can't see if your line is bent or positioned correctly, you may want to try and losen the line and reposition it...Below are photos of my '99 with the complete T1 set up.
Hope these photos help.
Old Dec 29, 2009 | 05:04 PM
Slow Z06's Avatar
Slow Z06
bend it
Old Dec 29, 2009 | 06:53 PM
C5_Z06's Avatar
C5_Z06
[QUOTE=69;1572576240]
Thanks! I've been looking at the pics and the different perspectives makes it a bit tricy to see what's different. It sure looks like you've got about 1/2" or so of clearance where the pipe is hitting the bar on my car. I need to take a closer look at my car to see what's going on. I assume if I losen the line to adjust the pipe the gas will escape?
Old Dec 29, 2009 | 06:58 PM
SJPD's Avatar
SJPD
Originally Posted by TXZ0603
bend it
no big deal
To T1 swaybar installation problem
