I have ~80k on the original sensors in my '02. Lately I've noticed a slight dip in fuel economy. While I'm guessing it's just a case of winter car blues (yes, it's actually getting cold in central FL ), it got me thinking about possibly swapping them out.
And any thoughts on brand of sensor? Advance shows NGK "universal fit" (no idea what exactly that means) sensors for ~25 and Bosch exact fit sensors for ~50.
TIA
you know how to check error codes on the dash? if you have no errors your fine. they can last a very, very long time well over 100.000+ miles
Yes, I've checked the codes and have none. O2 sensors however get "lazy" over time and while still operating in range (hence not throwing a code) can affect your performance and fuel economy. It's actually pretty common on C5s from what I've read.
Owned C5s for 12 years and never heard of this common problem before this thread.
And I'd like to point out that bad sensors dont always set Check Engine Light..
A lazy sensor causing the motor to run rich can easily be hidden by the Cats working overtime and cleaning it up by the time the 2nd O2 sees anything is wrong..
How do I know? my gas mileage plummeted.. but no CEL was lit.. I cleaned the MAF and the air filter... to no avail.. Added a bit more air to the tires.. No help..
I noticed while walking behind the car when it was running in the garage that it stunk.. Strong hydrocarbon smell.
I decided to replace the O2's. Immediately after I replaced them I went to "smell" the exhaust.. It smelled like warm humid air.. thats it.. no eye burning smell..
Like many have stated, check the filters (air and fuel particularly), PCV valve, clean your TB, plugs and wires, etc. I will be the first to throw out that O2 sensors are NOT good for the life of a vehicle, and in fact are meant to be replaced in the neighborhood of every 50-70K miles (GM, Ford, Dodge, etc all agree)! I have many calls every week where tunes are out of whack, mileage is lacking, power is down, etc due to O2 sensors that have never been changed. They build up gunk just like the spark plugs and over time lose their ability to do their job!
100% AGREE! Data log the engine and see if you have NORMAL O2 sensor operation. Once its warmed up, It should have O2 sensor voltage output from 1 millivolt to 90 millivolts. The PCM will read the sensor voltage and alter fuel injector pulse width to cause the senor to read HIGH- LOW- HIGH- LOW,,,,,,,,,etc
Learned this the hard way. Go to the EPA web site and make sure they have switched you to a "winter blend" of fuel. If they did there is more butane in the fuel and a corresponding decrease in fuel mileage.
