throttle body bypass tube?
Old Jan 6, 2010 | 09:32 PM
cvprepboy's Avatar
cvprepboy
Default throttle body bypass tube?
Is it worth getting a throttle body by pass tube, and a 178 degree thermostat? or throttle body flow booster air foil?
Old Jan 6, 2010 | 09:37 PM
lucky131969's Avatar
lucky131969
Ahhh....are these questions related to a C4 or C5? ......you're throwing me off with the throttle body air flow mod....
Old Jan 6, 2010 | 09:43 PM
cvprepboy's Avatar
cvprepboy
this is 04 c5. I have found this website, this product is called a Thorrle body flow booster air foil, is advised that it improves air flow and it increases HP by 12 HP
Old Jan 6, 2010 | 09:49 PM
lucky131969
I'll bite. Website link please.....
Old Jan 6, 2010 | 10:36 PM
ljthe2nd's Avatar
ljthe2nd
Don't waste your money. The air is only in the throttle body for a millisecond as it travels to the intake, not long enough for the temperature of the throttle body to affect it. If you feel the need to needlessly waste your money on a throttle body bypass, you can buy the parts to make your own at your local Lowes or Home Depot for about $3.
Old Jan 7, 2010 | 12:01 AM
cvprepboy's Avatar
cvprepboy
it is an item in ebay, catorgory if you type: c5 throttle body scroll down to you see booster air foil
MTPZ06's Avatar
MTPZ06
None of these are worth doing for themselves...if you are doing a coolent flush for scheduled maintenance, you can throw a low temp t-stat in. It won't do anything until you have a tuner turn the fans on sooner though. TB flow booster...no, just no. If you want a ported TB, then go ahead and do the bypass while the TB is off. But none of this is worth any real HP. Spend the money on a good cold air intake like a Vararam or Honker...those actually make real HP that you will notice.
Old Jan 7, 2010 | 12:05 AM
MTPZ06's Avatar
MTPZ06
Even worse...stay away from that crap on ebay. Most likely its some piece of crap that will get sucked into the intake and damage a valve or a piston.
Old Jan 7, 2010 | 12:10 AM
c5blkvetteguy's Avatar
c5blkvetteguy
The throttle body by pass tube is a great idea if you plan on swapping out the intake manifold at a later date. Thats about the only thing its good for...saving time when working on other things.
Old Jan 7, 2010 | 12:18 AM
lionelhutz's Avatar
lionelhutz
I bypassed mine because I had it apart and that short little 90 degree hose is a pain in the *** to get off. I also found that 90 degree hose a little rotten so it got replaced with a straight piece and a coupler.
I did that last winter. Last summer, I had a very slight throttle tip-in surge. I'm not 100% sure if it's related but I changed 2 things, the bypass and the filter in the Vararam so it has to be one of the 2 causing the surge. Haven't bothered changing it back yet but next summer I might just to see if that's the problem.
Peter
Old Jan 7, 2010 | 01:03 AM
striper's Avatar
striper
The airfoil thing is a waste of money, it does nothing. Anything you insert in the throttle body has to in some way reduce the diameter of the opening, which is backwards if you're trying to increase airflow. The lower temp thermostat is useful if you get stuck in summertime traffic often, however you need a tuner to adjust the fan temp turn-on and off or the thermostat will accomplish nothing. On a previous C5 I owned I did a throttle body bypass. The only thing you need is a rubber hose long enough to connect to both ends where the bypass kit would attach. I just attached the hose directly from the intake manifold to the radiator and eliminated the whole assembly. Costs about 2 bucks. It probably has a minimal affect on performance but it makes it easier in the future anytime you might need to remove the throttle body. No disconnecting and coolant drips.
BTW, if you ever do have cooling issues, before you do anything else, clean the radiator. Alot of junk gets up in there. Makes a screen that blocks the radiator cavity from having trash going up and clogging the radiator.
Old Jan 7, 2010 | 06:28 AM
PRE-Z06's Avatar
PRE-Z06
Peter
I doubt it's from the bypass, I assume by changing the filter you mean washing/oiling? If that's the case, some extra oil could have gotten on the MAF wire and needs to be cleaned off with electrical cleaner
Old Jan 7, 2010 | 06:39 PM
lionelhutz's Avatar
lionelhutz
Changed from the old foam and wire mesh to the new filter. The MAF has already been cleaned with no change.
Peter
Old Jan 8, 2010 | 01:38 AM
PRE-Z06's Avatar
PRE-Z06
Peter
I see, sorry to hear that...hope you get it figured out.
Old Jan 10, 2010 | 11:46 AM
Johnny Hardcore's Avatar
Johnny Hardcore
Good advice.
Old Jan 10, 2010 | 12:14 PM
lionelhutz's Avatar
lionelhutz
The only useful (debateable here too) airfoil I can recall is the one for the 2 bore TPI and LT1 engines. The LS1 is a single bore throttle body so no place for that thing.
Peter
Old Jan 10, 2010 | 12:41 PM
JCamaro's Avatar
JCamaro
Peter
Yeah, I had one of those things in the TB of my LT1 camaro....of course I put a vette TB and the airfoil on at the same time....which did give me way better throttle response....but I'd never be able to tell you which one was better for the $$$
To the OP,
Just get the bypass and a ported TB....I've seen them on here for as cheap as $90 plus $3-5 for the coolant bypass and you're good to go. That Thermostat will require you to reprogram the fans...if you don't have a programmer...you'll need a tuner to do it...and you might as well get a street tune done at the same time to wake up the car.
To throttle body bypass tube?
Old Aug 14, 2010 | 10:35 AM
Tulsa Vette Guy's Avatar
Tulsa Vette Guy
Question, when routing the hose to bypass the throttle body, do you need to close off the hose tube from the hose the you removed?? or just leave it open ??
Old Aug 14, 2010 | 12:09 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Just port your own TB or purchase a ported TB from a forum vendor. You will gain some throttle response. Maybe a few hp but nothing to write home about.
BC
Old Aug 14, 2010 | 12:57 PM
lionelhutz's Avatar
lionelhutz
The 2 ports on the throttle body that you disconnect the hoses from can be left open.
Peter
